Author Topic: CB400 Rectifer / regulator  (Read 771 times)
Offline Integra99
« on: September 08, 2017, 09:17:14 AM »
I'm just in the process of rebuilding my CB400f... while the frame is away I'm sorting the loom. A quick question I'm upgrading to a reg/rec combined unit, my new one has two feed wires, white and black but the original rectifer has a green wire also... does anyone know if this can be ignored ?
Thank you
Re: CB400 Rectifer / regulator
« Reply #1 on: September 08, 2017, 11:16:45 AM »
if you are using the RR24 combined unit,
 the other was regulator ground/earth,so can be ignored
Offline Integra99
« Reply #2 on: September 08, 2017, 03:22:43 PM »
Ok great so the spare green is just an earth.. so I can tape it up?
I'm using a yamaha XS750 combined unit as I have a spare.. has exactly the same plug and 2 rectifier outputs just like the David Silver upgrade.
« Reply #3 on: September 08, 2017, 04:31:15 PM »
 this is the unit I was talking about,
http://www.electrexworld.co.uk/acatalog/RR24.html
 use the link to check wiring details
Offline gtmdriver
« Reply #4 on: September 16, 2017, 08:19:58 PM »
I'm using the Electrex World unit on my CB350F and the green wire can just be taped up out of the way.
Online Bryanj
« Reply #5 on: September 18, 2017, 01:44:29 AM »
The XS750 was notorious when it came out for the reg rec failing, so much so Yamaha modified it to two separate units--then a few years later back to a combined one
Offline Integra99
« Reply #6 on: September 21, 2017, 08:50:30 AM »
Thanks all thats most helpful cheers!!
