Author Topic: faulty oil pressure sensor.???  (Read 1401 times)
Offline Woodside
« on: September 19, 2017, 07:38:16 PM »
is there a way of testing a oil pressure sensor...
just been for a ride out and at lower revs say up to 2000 the light gradually glows on ...give a gentle rev and it dims off...
everything is nice and wet up top...
i have an order with ds so may add a sensor to it tomorrow..any other thoughts
Offline Woodside
Re: faulty oil pressure sensor.???
« Reply #1 on: September 19, 2017, 07:38:44 PM »
500 by the way
« Reply #2 on: September 19, 2017, 07:58:07 PM »
Exact same symptoms as on my CB400/4 last summer Jason. Mine was the sensor playing up, fitted a new one and all OK.
Offline Woodside
« Reply #3 on: September 19, 2017, 08:08:55 PM »
good just wanted a second opinion...the problem seems
along those lines
i will call silvers in the morning and add it to my small order ....save a few sheckles on postage
« Reply #4 on: September 19, 2017, 08:33:36 PM »
Sounds like a oil pressure switch or the pump O'rings have gone brittle. Funny enough I have just started selling the O'ring repair kit for the 500's  ;)
Offline Woodside
« Reply #5 on: September 19, 2017, 08:45:36 PM »
oohh
ill pop a new switch in anyway as i dont have a known spare here .....if not ill tap you up for a repair kit
« Reply #6 on: September 19, 2017, 08:58:24 PM »
oohh
So beans on toast for me tomorrow while Sliver enjoys a fat steak and a bottle of wine  ;D ;D ;D
Offline Woodside
« Reply #7 on: September 19, 2017, 09:13:34 PM »
stick with the beans....probably save you from a bout of gout....
« Reply #8 on: September 20, 2017, 08:01:47 AM »
My gout is playing up, I blame a McDog burger on Monday. That's another guilty pleasure off the list.
At the risk of sounding like Eyore, you should get an oil pressure gauge on it, the switch may be working as intended. My local garage has one with a variety of adapters, yours may have one too. Then we can compare the reading with what Honda says it should be.
Somewhere on here is a nearly identical thread from my denial phase when I was trying to blame my CB750 oil light coming on at low revs on anything other than actual low oil pressure. That ended in an engine rebuild to fix the borked main bearings, eventually.
« Reply #9 on: September 20, 2017, 09:50:44 AM »
I'd be a bit suspicious with it too,  the top end oil supply is effectively not measured for pressure as far as I can see so oil there is just confirmation of that. The pressure light is responding to pressure in the main bearing galleries and pump system so you can have some leak down within that and still see oil through the tappet covers.
Worth asking if the oil is new? Any dilution with petrol makes it loose pressure.
Offline Woodside
« Reply #10 on: September 20, 2017, 01:22:22 PM »
well ive added a sensor to my order so should have it in a couple of days...i wont stress untill ive fitted that...
i shall report back then start to brick it
Offline paulbaker1954
« Reply #11 on: September 20, 2017, 02:21:14 PM »
For what its worth the OP sensor is a standard part that Honda uses on all sorts of stuff.
Get the part number and do a google like I did you will fid them LOADS cheaper than DS.
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
« Reply #12 on: September 20, 2017, 03:53:34 PM »
It's something you'd always hope,  that it's the pressure switch giving you a false report. Makes your heart sink when you get it come on though.
As you say though,  fingers crossed for a good outcome with a new one.
« Reply #13 on: September 20, 2017, 08:51:33 PM »
I would say it is still typical symptoms of a pump in need of a O'ring kit  ;D ;D ;D ;D ;D
« Reply #14 on: September 20, 2017, 09:21:23 PM »
  guess who may be selling new O ring kits !!!
 the most difficult is the 3 counter sunk on the oil pump,and yes,that O ring did leak !!!
