Author Topic: Rebore  (Read 998 times)
Offline ogri211
Rebore
« on: September 26, 2017, 06:40:42 PM »
I have got a new set of barrels that need rebored, I have ordered .5 oversize pistons, today I went to see a local machine shop and he quoted me £50 per bore for rebore and honing is this the normal price that I should expect to pay for this job.
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
Re: Rebore
« Reply #1 on: September 26, 2017, 07:37:59 PM »
Probably about average, BUT make sure they are familiar with Honda bike engines regarding piston clearance tolerances when boring, Honda's have far tighter clearances than car engines!
Offline RGP750
Re: Rebore
« Reply #2 on: September 26, 2017, 08:10:22 PM »
www.milwaukeemuscle.co.uk
This guy does mine as he is a customer ,i think he charges about that , he also does John Wyatts bikes .
I think Trigger on here is cheaper and he  knows what he is doing .
good luck
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: Rebore
« Reply #3 on: September 26, 2017, 09:06:38 PM »
You have to find a engineer that knows the right clearances on a old Honda, a lot of boring I do these day is putting right were someone has had a re bore and it is way out of spec.
Offline ogri211
Re: Rebore
« Reply #4 on: September 27, 2017, 10:13:26 AM »
thanks for the replays, the guy was recommended by a friend he said all the boys who do the racing use him  its an old boy who works himself and does a lot of old British stuff so I,m sure he will be good I will stick with him as he came highly recommended.
Re: Rebore
« Reply #5 on: September 27, 2017, 10:47:13 AM »
  just be careful he knows how tight the clearence is,its about a quarter of the brit stuff !!
Re: Rebore
« Reply #6 on: September 27, 2017, 10:50:47 AM »
If he does all old Brit engines just remind him the  tolerances are absolutely miniscule compared to Brit bikes, I mean MINISCULE  ;D
Re: Rebore
« Reply #7 on: September 27, 2017, 10:51:41 AM »
Haha, beat me to it John
Re: Rebore
« Reply #8 on: September 27, 2017, 06:10:46 PM »
It doesn't mater if he does race, rally or NASA, if he does not know, he does not know  ;)
Re: Rebore
« Reply #9 on: September 27, 2017, 07:11:18 PM »
  it might be an idea to publish the clearance ,
 in simple figures, and advise the best way to achieve it,
IE;  measure the piston,and add X thou for clearance ??
Re: Rebore
« Reply #10 on: September 27, 2017, 07:22:12 PM »
I wish it was that easy Mr Webley, it all depends on the grade of alloy used to make the piston, different alloy expands at different temperatures. Honda original pistons were made from a very high grade cast and the clearance can be kept at a minimum. A less grade will expand more and would require more clearance  ;)
