Author Topic: CB400/4 ENGINE STRIP, ASSESSMENT AND REBUILD BY JULIE - NOW COMPLETE  (Read 49629 times)
« Reply #15 on: October 02, 2017, 09:59:18 PM »
Maybe that's what NGK recommend, rightly or wrongly!
« Reply #16 on: October 02, 2017, 10:41:07 PM »
It affected the 405 line sets rather than the 625 line for technical reason which I've forgotten about.  Something to do with the way the luminance is modulated onto the carrier wave.
« Reply #17 on: October 03, 2017, 12:31:10 AM »
Metal shrouded caps are resistive ...  some are 5k Ohms , some are 10k Ohms.
« Reply #18 on: October 03, 2017, 08:03:39 AM »
There's a four stroke scooter ( with Valentino Rossi paintwork) that passes our house each day and trashes the TV signal,  it's Freeview via an aerial.
Also the po-leece where above in a helicopter which blitzed the signal, presumably emergency rf channel transmitter.
Offline kevski
« Reply #19 on: October 03, 2017, 08:42:04 AM »
Oh dear Julie, it looks like your thread has been taken over by the resistance😊
« Reply #20 on: October 03, 2017, 08:43:40 AM »
I understand the original main aggressor was the Kawasaki H1, which in the late 60's, was the first Japanese bike to use CDi ignition as standard fitment. Lots of modern vehicles now use metal shrouded caps to reduce RFI. This is probably necessary in order to meet the stringent 'E' mark approvals for automotive electronics. I have got equipment through those approvals and I can tell you it's not fun and horrendously expensive.
« Reply #21 on: October 03, 2017, 08:55:35 AM »
Very good Kevski  ;D ;D ;D
« Reply #22 on: October 03, 2017, 09:35:19 AM »
That is a good one kevski  :)
I do think there's more to the resistance in this motor though,  it'll be interesting to see inside it when you get it apart.
The resistance increase when it was running both plugs and caps with R shouldn't really have an affect at tickover. What it does is extend the spark duration from its initial start point. This in itself doesn't do much without something to burn,  so if youve got an old motor that's a bit windy and burning a little oil then you do have a source that is combustible and not controlled by the throttle slides.
That sort of mix is reluctant to fire but can be encouraged by a longer spark duration, which maybe what was happening inside this one.
It's an area they are having a punch up about in F1 as they are restricted in how much fuel they can use, but it looks as though they have been burning the oil as well. They even ran special oils in qualifying that people assume are orientated toward combustion which has been banned. They've now imposed maximum oil burn limits as well to try and prevent it.
« Reply #23 on: October 03, 2017, 09:35:33 AM »
To hijack a hijack.....
I seem to recall the metal shrouds were fitted as the GPO at the time complained if they weren't fitted they caused interference.
My CB750 from South Africa still had metal shrouds on the inside cylinders, though I replaced them in search of a misfire.
Before I got a ham radio licence I was into illegal sideband CB radio. I gave up doing it from home, after I got a visit from GPO inspectors, having been stupid enough to use the radio during Eastenders, wiping out the neighbours' TVs, so I went mobile, using a 100 watt setup from my car. I was talking to a mate as I drove down the full length of Deansgate in Manchester, looking in my mirror I saw to my horror lots of little flashing lights, as I had set off alarms all the way along the street!
Keep us posted on the rebuild Julie, has Graham sold you an engine stand yet?
« Reply #24 on: October 03, 2017, 09:43:21 AM »
He has tried very hard to sell me one Dave but I'm too tight to buy one (typical CB400 owner !!!) This is going to have to be a quick strip/ rebuild as I'm incurring tool hire charges and workshop space charges 😭😭
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #25 on: October 03, 2017, 10:08:38 AM »
That's bad Julie,
Tool hire and workshop space charges - Trig offered me overnight accommodation for next years C90 trip to Deutschland - unfortunately not passing your place - but he didn't mention CHARGES 🤓
Looking forward to seeing inside the motor,
Ian
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #26 on: October 03, 2017, 10:29:31 AM »
Very much looking forward to the engine work Julie,  gear boxes have always been some thing of a 'black art' to me.
Hijacked thread, as Ash mentioned the H1/H1A with CDI ignition was a big problem for Kawasaki in the USA 1968/69. I understand that the imported Euro versions thereafter where H1B with points ignition.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #27 on: October 03, 2017, 12:26:21 PM »
That's bad Julie,
Ian
He just sends the invoice later  ;D ;D ;)
Come on Julie the top end should be off by now.
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
« Reply #28 on: October 03, 2017, 01:07:21 PM »
That's bad Julie,
Ian
He only charges me for workshop facilities Ian....no one else
Accommodation is FOC to everyone....including me  ;D ;D
« Reply #29 on: October 03, 2017, 01:14:19 PM »
That's bad Julie,
Ian
The top end is almost off Paul. I have the rocker cover off, camshaft out and just started on the head bolts but I have got stuck on one of those nuts right down by the spark plug port, I just can't get it to move. I will have to wait for Trig to come back as I'm worried I will muller it, so need his input. I can't progress further with the head bolts as it says remove them in sequence....so I'm doing some ironing instead  :'( :'( :'( I will give a proper update later wish some pics. (On the engine that is, not the ironing  ;D ;D)
« Last Edit: October 03, 2017, 01:36:50 PM by Nurse Julie »
