Author Topic: Gear lever.. play ? cb400  (Read 419 times)
Offline Integra99
« on: October 31, 2017, 11:52:02 AM »
A quick update... had this bush and washer made up.. lovely job!
Offline GiannisFour
Re: Gear lever.. play ? cb400
« Reply #1 on: October 31, 2017, 04:31:58 PM »
Hi
having the same problem,nice job you did! can you give more details?
thanks
CB500 K1
CB400 F2
« Reply #2 on: October 31, 2017, 06:26:58 PM »
That's nicely done.  Thanks for sharing
Offline Integra99
« Reply #3 on: November 01, 2017, 11:33:25 AM »
Yes we took about .2mm from the shaft so there was less to take out of the selector , the problem was the selector had worn in an oval shape and it was better to reduce the shaft dia a little to compensate, I had help from a friend who repairs steam engines so a few cups of tea and sorted, we made a washer either side and all held in with a split pin..  there was so much play in it before, gear changes will be much better now!
