Author Topic: Boyer Installation Images  (Read 574 times)
Offline paulbaker1954
« on: November 01, 2017, 10:15:46 AM »
Hi Folks
I saw in a post a while ago some images from a member of their BOyer installation using some made up brackets (as opposed to the "tie wrap" approach.
I cant find the post can anyone direct me please
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Online AshimotoK0
Re: Boyer Installation Images
« Reply #1 on: November 01, 2017, 10:29:57 AM »
Offline jon stead
« Reply #2 on: November 01, 2017, 12:11:30 PM »
Hi Folks
Hi, my B.B. micro power unit was installed under the seat in the tool tray.
Bear in mind, if you’re using Boyer’s mini coils, they’re 6volts and need to be wired in series, unlike the original coils that are 12 volts and wired in parallel.
If you follow Boyer’s installation instructions you can’t go wrong.
« Reply #3 on: November 01, 2017, 12:46:33 PM »
Thanks Ash but that wasn't the post I was searching for it was one that also showed some bracketry for mounting the Mini Coils
I'll keep searching !!
« Reply #4 on: November 01, 2017, 05:44:06 PM »
I think this may have been on Royhall’s CB350F?
Offline jon stead
« Reply #5 on: November 02, 2017, 06:01:09 AM »
I’m away at present so can’t get better pictures, so below are two I had on my phone. Basicaly, two m6 studs with suitable spacers. Hope this helps?
Oh, just remembered, I can’t take more pictures, as I took the Boyer ignition off, put original coils back on and fitted a Dyna S System. No difference. I’m still chasing my problem. Nothing wrong with Boyer system.
« Last Edit: November 02, 2017, 06:14:49 AM by jon stead »
« Reply #6 on: November 02, 2017, 08:11:27 AM »
Dont know if it helps but this was my effort. To be honest it worked very well and I can return to standard anytime as may be required.    http://www.sohc.co.uk/index.php?topic=8257.165
