Author Topic: CB550K Front Brake problem  (Read 877 times)
Re: CB550K Front Brake problem
« Reply #15 on: November 03, 2017, 06:14:51 AM »
What happens is crud gets into the seal groove in the caliper body and makes the seal tight on the piston so to do it properly remove the piston and seal, glean out the groove till its perfect and reassemble.
https://www.ebay.co.uk/itm/Honda-CB400F-400-4-400-Four-Front-Brake-Caliper-Piston-Stainless-Seal-KIT013/262018047322?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Gets you a stainless piston and new seal for £29
« Last Edit: November 03, 2017, 06:16:55 AM by Bryanj »
