Author Topic: Boyer ignition fitting a lesson learned  (Read 1349 times)
Offline paulbaker1954
« on: November 10, 2017, 02:06:15 AM »
I just finished fitting the Boyer system to my 4 but learned a hard lesson on the way that I thought I’d share.
The Boyer instructions say to remove the bob weighs and springs but do not make it clear you also have to remove the advance/ retard cam off the advance/ retard unit shaft as well.
I missed this and was confused as to why the stator plate did not fit properly and why the mag rotor fouled the chrome cover.
In my confusion I filed off the lugs on the end of the advance unit to get it to fit (unsuccessfully) without fouling the cover (thanks to Ash for replacement advance/ retard unit)
The answer was simple as always in hindsight, in that if you don’t take off the cam bush the stator plate won’t fit over the end of the advance unit properly and the mag rotor won’t fit over the end of the advance unit shaft.
It all comes down to a missing comma!!
Instruction 16 in the Boyer instructions says
“Remove the cam bobweights and springs from the advance retard unit”
It should say
“Remove the cam, bobweights and springs from the advance retard unit”
Amazing what confusion a missing , can lead to!!
As the saying goes
“Eats shoots and leaves” or alternatively “Eats, shoots and leaves”
I have notified Boyer by the way !!!
« Last Edit: November 10, 2017, 02:20:22 AM by paulbaker1954 »
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Boyer ignition fitting a lesson learned
« Reply #1 on: November 10, 2017, 07:40:50 AM »
Missing capitals can also cause confusion,  as in;
I helped my uncle jack off his horse
I helped my uncle Jack off his horse
Offline Rozabikes Tim
« Reply #2 on: November 10, 2017, 08:56:05 AM »
My wife feels it would be wrong to send my children into school with that to show their English teacher... Can see why? :P
« Reply #3 on: November 10, 2017, 09:10:32 AM »
Send here in with this then. "Swim swan over the sea, swim swan swim. Swan swam back again, well swum swan". What the F is that to do with SOHC bikes  ;D ;D I haer everyone mutter ...Glad the auto advance arrived OK Paul.... nobody answered my query though ...Difference between CB500/4 auto-advance mechanisms  marked AD125-01 & AD125-02 (02 is marked '323' .... 01 isn't)
« Reply #4 on: November 10, 2017, 09:13:35 AM »
Ash
Have you checked if there is any difference with the max advance marks between 01 and 02
Just a wild guess
« Reply #5 on: November 10, 2017, 09:25:18 AM »
Quote
Ash, I have no idea what you're talking about. Where are we supposed to find these numbers?
« Last Edit: November 10, 2017, 09:29:07 AM by deltarider »
« Reply #6 on: November 10, 2017, 09:51:19 AM »
Quote
Stamped onto the plate of the auto-advance !
Some info here:-
http://forums.sohc4.net/index.php?topic=113338.0
http://forums.sohc4.net/index.php?topic=113338.25
« Last Edit: November 10, 2017, 10:06:09 AM by AshimotoK0 »
« Reply #7 on: November 10, 2017, 12:31:08 PM »
Thanks, so it's about Hitachi only, right? The CB500/550 models came with two types:
30220-323-005 (Hitachi) and 30220-323-154 (Toyo). Mine are both Toyo (TEC) so that explaines why I couldn't detect a number. BTW, a member of the German site discovered that the springs varied in length between the Toyo and Hitachi advancers. Hitachi takes 20mm and Toyo would have 21mm springs.
« Reply #8 on: November 10, 2017, 01:17:25 PM »
That thread is really interesting Ash, I'd not seen that in the things I've read about ignition.
The post of Hondaman on 27th may 2017 is very pivotal to some of the discussion we've had on here about ignition systems. The length of spark is critical as far as I can see for these engines.
The various spec for advance mechs appears to be more tolerated on the 750 motors when used. Their sensitivity to that area is much more likely to have an impact on the smaller capacity engines and particularly when used on the 400. I belive it's this area that influences the detonation that's apparent on some of these engines.
« Reply #9 on: November 10, 2017, 04:14:59 PM »
I read this post this morning and am still laughing at teatime. Brilliant!!
« Reply #10 on: November 10, 2017, 09:11:51 PM »
« Reply #11 on: November 10, 2017, 09:49:12 PM »
Don't know if it's just me but on those two Hitachi mechs the top dead centre T mark is in the same position,  but the F mark is moved from one example to the other.
This would give a different static timing start point,  and so different total advance also if the swing is the same for the two.
The 01 example appears to have something like a couple or 4 degrees more static than the 02.
« Reply #12 on: November 10, 2017, 10:36:35 PM »
Or looked at from the opposite direction ie the 02 came later if on the same engine,  then the ignition static setting is retarded.
Has the advantage of not changing the setup spec for a workshop, and manuals still being accurate regarding routine. It effects a change without being visible unless you have to replace parts.
Which bike is the 323 fitted to? as the other 3 look to be the same as each other.
Offline Seabeowner
« Reply #13 on: November 10, 2017, 11:41:20 PM »
Couple of TEC 323 (500) advancers:
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline Seabeowner
« Reply #14 on: November 11, 2017, 10:40:12 AM »
Following up on the above, I found it difficult to find the spec for these, but internet info (treat with caution) seems to show:
300 (750) advancers:  10 deg static:  35deg fully advanced.
323 (500) advancers:    5 deg static:  30deg fully advanced.
I have a Boyer system that I picked up for £10 and presume as it uses the original (323 in my case) advancer back plate to set the timing, I presume that it is right for my 550.
