Author Topic: Spark plug Caps  (Read 640 times)
watty51
Spark plug Caps
« on: November 11, 2017, 04:30:13 PM »
Does anyone know if the Spark plug caps from David Silver are 5000ohm suppressed   www.davidsilverspares.co.uk/CB350-FOUR/part_28361
Im just fitting a Boyer Bransden Electronic Kit 00289 and the fitting guide says the caps must be to this spec.
Many Thanks
Offline Seabeowner
Re: Spark plug Caps
« Reply #1 on: November 11, 2017, 04:39:31 PM »
The 05 is 5kohms, so yes.
The NGK plug catalogue is here:
https://www.ngkpartfinder.co.uk/files/NGK_Spark_Plug_Covers.pdf
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
watty51
Re: Spark plug Caps
« Reply #2 on: November 11, 2017, 04:53:24 PM »
Thanks for the quick reply.
Thought the VD05F partcode had something to do with it.
Just checking
Offline kevski
Re: Spark plug Caps
« Reply #3 on: November 11, 2017, 07:49:33 PM »
Do not use resistor plugs with these caps it will create bad running.
watty51
Re: Spark plug Caps
« Reply #4 on: November 11, 2017, 08:06:54 PM »
I am using NGK D8EA Plugs at the moment. Will these be ok
