Author Topic: 400 Four strip down.  (Read 2216 times)
Offline GregShiv
Re: 400 Four strip down.
« Reply #15 on: December 06, 2017, 10:38:12 PM »
That barrel has a few broken fins that will need repair. Sure sign that the heads been screwdriver prised off at some point.
I think I have counted 3 fins that are broken.
What is the best way to get them repaired, TIG build up?
1983 Suzuki GSX550ESD
2013 Aprilia SL750 Shiver
1976 Honda CB400F
Offline GregShiv
« Reply #16 on: December 06, 2017, 10:42:32 PM »
As Julie has posted,  those cam main journals look to be showing wear characteristics.
In addition,  they show a pattern of wear symptomatic of metal embedded into the softer aluminium head bearings. If you can feel any "spikes " in the head bearings by running your fingernail round them,  then that would indicate that they'd need to be corrected somehow before reassembly.
It's something you'd associate with the oil filter pressure release valve being operated so that contaminated oil is passed round the engine.
If that's the case,  you may see the same type of marks when you get to the crank bearings also as they get the oil first.
There is a spike in one of the head bearings, apparently the bottom end was rebuilt 20 years ago and had a new primary chain fitted.
But it looks like the cam chain tensioner has been fitted to the wrong hole, I wonder what sort of damage that could potentially have caused?
« Last Edit: December 06, 2017, 10:59:38 PM by GregShiv »
1976 Honda CB400F
Offline GregShiv
« Reply #17 on: December 06, 2017, 10:47:37 PM »
Update on engine strip.
I have taken the head off but the block is reluctant to even move, wooden mallet did not help.
Any suggestion as to the best way to get the block off without further damage to the aluminium?
« Last Edit: December 06, 2017, 11:02:16 PM by GregShiv »
1976 Honda CB400F
Offline GregShiv
« Reply #18 on: December 06, 2017, 10:53:29 PM »
More pictures.
Why does one of the pistons have a 4 moulded into the top?
The pistons don't look too bad and the condition of the valves from my untrained eye look ok.
Initial look at the bores seem ok.
What are the opinion of the group?
« Last Edit: December 06, 2017, 11:02:25 PM by GregShiv »
1976 Honda CB400F
Offline GregShiv
« Reply #19 on: December 06, 2017, 10:57:03 PM »
The frame and all black metal bits are at the powder coaters, the frame is just going to get "shot" blasted so that I can get the rust holes on the frame assessed and repaired.
1976 Honda CB400F
« Reply #20 on: December 07, 2017, 09:01:43 AM »
As you say,  generally from those pictures the bores don't look bad as the hone marks are still clearly visible. A better view of them would be wise after they are removed.
Cylinder head, initially leave valve in and with it upside down on a bench,  fill each combustion chamber with something like thinners (or vodka  :) )  and leave to see if it seeps out past the valves and runs out the ports. It'll tell you if they are sealing or not as initial inspection.
Replacing fins,  use duralumin sheet cut to rough shape and tig tac to barrels,  then complete weld followed by coarse emery or file to shape.
Clutch cover,  if it was welded with any contaminants like oil in material it can be porous so refinishing it could expose some holes. But worth trying to reshape the outside,  use emery cloth and plenty of paraffin to get good finish. If it's too much of a problem it may be worth sourcing another if you cannot get at decent cost.
Getting barrels off,  someone else on here went through recently (maybe worth search for post)  but I'd start by putting penetrating oil down the stud holes that are the external ones. They can be really stuck by the base gasket and maybe worth tapping at centre front and rear with softwood drift to get the gasket to release. Don't prise the fins though.
Added to clarify,  try to tap barrels back and forth not upwards,  aim to get the base gasket to release before you go any further.
« Last Edit: December 07, 2017, 09:38:25 AM by K2-K6 »
« Reply #21 on: December 07, 2017, 09:42:55 AM »
I had difficulty getting mine apart. After checking again that all the bolts had been removed it was a case of persevering with the mallet and eventually it started lifting. As mine had the original factory fitted gasket in situ, it was well stuck together. Don't attempt to prize up by the fins, it will end in more tears  :'( :'(
« Last Edit: December 07, 2017, 03:26:12 PM by Nurse Julie »
« Reply #22 on: December 07, 2017, 09:40:24 PM »
The clutch cover repair is pretty ugly. If you grind it down smooth you might open up a hole or crack underneath and need another weld to repair. What's the inside of the cover like?
The picture of the other side of the cover is included.
Look just as bad but there looks to be plenty of metal on both side to get an improvement?
I noticed that later. That's the problem when you view it in a hurry! 😕
Good luck with the grinding and polishing. ☺
Offline GregShiv
« Reply #23 on: December 08, 2017, 12:24:09 AM »
Thanks for the reply's guys.
I have put plenty of penetrating oil down all the stud holes and will give it another try over the weekend.
I will then give everything a good clean so I can examine it all properly and will post a few pictures.
I am planning on getting all the alloy parts aqua blasted at some point.
1976 Honda CB400F
Offline GregShiv
« Reply #24 on: March 11, 2018, 12:09:57 PM »
Update.
The frame has been welded and realigned at Maidstone Motorliner. Headstock, exhaust hanger and rear frame rails were all out of alignment.
Where the metal had rusted at the rear left shock mount it had also rusted at the frame rail this was all welded/brazed and made good.
frame has now been powder coated along with all the other black parts but I am still waiting to get the top yoke back as the powder coat had bubbles showing.
Still waiting to get the engine casing back from the vapour blasters!
[ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
1976 Honda CB400F
Offline GregShiv
« Reply #25 on: March 11, 2018, 12:16:30 PM »
More frame pictures.
1976 Honda CB400F
Offline GregShiv
« Reply #26 on: March 11, 2018, 12:21:07 PM »
The frame as it is now, and yes it is in the house. I have a very tolerant wife ;D
1976 Honda CB400F
« Reply #27 on: March 11, 2018, 12:24:19 PM »
Looking good Greg. All bikes should be in the house !!! ;D ;D ;D ;D ;D
Offline GregShiv
« Reply #28 on: March 11, 2018, 12:25:40 PM »
Here are some pictures of the bike as it was picked up when I bought it late last year.
No indicators or mounts, non standard seat, none standard rear mudguard, loom bodged up etc
« Last Edit: March 11, 2018, 12:41:36 PM by GregShiv »
1976 Honda CB400F
Offline GregShiv
« Reply #29 on: March 11, 2018, 12:30:29 PM »
I agree Nurse Julie  :)
1976 Honda CB400F
