Author Topic: Strange whine from front of bike  (Read 631 times)
Offline florence
« on: November 25, 2017, 10:38:17 AM »
Approaching a local town in the pouring rain after about a fifteen mile ride, a terrible grinding whine started to come from the front end.  I touched the brake momentarily to see if it was coming from the disk, no change.  Eventually, after much pointless inspection, I worked out it was coming from the speedo and after a thump it went away for a moment but then soon came back.
I'm only relating this story in case it happens to anyone else, it was very worrying because I had recently had the front end to pieces to replace the mudguard and thought maybe I had forgotten to tighten something.
« Last Edit: November 25, 2017, 10:40:08 AM by florence »
Offline Tomb
Re: Strange whine from front of bike
« Reply #1 on: November 25, 2017, 12:35:45 PM »
I used to get a horrible whine from the rear of the bike, it went away now I'm single again ;D
I get the same on my 500, I've tried grease, oil, and WD40 on the speedo cable all of which made a difference but it can still come back and go randomly. The only thing I did think was it was when the weather was cold, which could be causing yours now.
Tom
'62 CB77 Sprinter
'70 CD175
'78 CB550 with sidecar
'80 Z50R
Offline florence
« Reply #2 on: November 25, 2017, 06:08:38 PM »
I think you are right.  Foolishly, in the summer I hardly rode.  Now it's winter I'm using every day.
I do have a spare but it doesn't record mileage which was a problem with MOT.  However, it had it's last MOT in May.  Next year it will be exempt, hooraay.....so will probably swap back.
« Reply #3 on: November 25, 2017, 06:32:52 PM »
::) ::) ::) ;D ;D ;D
Offline davidrsmith
« Reply #4 on: November 25, 2017, 09:52:47 PM »
Excuse my ignorance but doesn't a bike require an MOT every year,  or does it not need one when it becomes historic (40 years old)?
Dave
« Reply #5 on: November 25, 2017, 10:00:56 PM »
Offline Tomb
« Reply #6 on: November 26, 2017, 08:30:27 AM »
I'm surprised your speedo odometer causes a problem at the MOT, the speedo is not part of the MOT. MY CB72/77 doesn't have a speedo, and the odometer of the little Chinese CG125 copy I ride to work fell out of the speedo, neither of them cause a problem for MOT.
Another thing I noticed about the speedo whine was that it suddenly stopped as my speed reduced, almost like some internal resonance had started it. When I first had the problem I would coast to a stop trying to listen to it.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
Offline florence
« Reply #7 on: November 26, 2017, 01:05:30 PM »
I just meant that the mileage wouldn't change from one year to the next which I thought might look bad.
Also it's quite good to record mileage to know when to change the oil, i.e. every 1000 miles.
Offline Tomb
« Reply #8 on: November 26, 2017, 01:36:03 PM »
Gotcha, I thought you meant they questioned it.
Tom
'62 CB77 Sprinter
'70 CD175
'80 Z50R
