Author Topic: Sprsying /Painting engine  (Read 1270 times)
Offline Moorey
Re: Sprsying /Painting engine
« Reply #15 on: November 26, 2017, 10:42:22 PM »
Did you thin with white spirit, what % do you know.
Offline gtmdriver
« Reply #16 on: November 27, 2017, 12:27:24 PM »
Yes I thinned it with white spirit but I'm not sure what % I used. it's about 10 years ago now.
The paint itself is quite thick with a high solid content so I thinned it a little at a time until it went through the gun correctly.
Leave each coat to dry for a while. It doesn't dry as quickly as cellulose.
Offline Mr_Sheene
« Reply #17 on: November 28, 2017, 11:28:26 AM »
If you have trouble masking off small items you can get 'liquid mask' from art shops and model shops. It's latex and paints on. When it's dry it forms a rubber barrier over the part you're protecting. Model shops also sell 'low-tack' masking tape in various sizes. The mask can be suspect with some acrylic paints and can 'colour' plastics but I doubt that it'll harm an engine. When dry, you simply rub it off with your fingers.
