Author Topic: 1972 cb175 part ident help  (Read 863 times)
Offline RGP750
« on: December 04, 2017, 03:54:08 PM »
Hi All
Assembling 1972 CB175 gear box , gear change drum and came across the ring in the photos
lying on the bench.
i'm assuming it has come from the 175 as i can't think where else it has come from .
I can't find it in my parts book and Trigger has had a look in his micro thingies .
It's .9mm thick and has a small tag to stop it revolving i would think .
Any ideas welcome before i carry on and leave it out .
Cheers Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Offline haynes66
Re: 1972 cb175 part ident help
« Reply #1 on: December 04, 2017, 09:05:17 PM »
i remember stripping and rebuilding my little TL125 and similar rings were fitted inbetween some of the gears, spacers maybe? i reassembled it exactly as it was and everything worked ok. i dont know if it could be something similar...
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
« Reply #2 on: December 04, 2017, 09:10:42 PM »
I've got something like that on the 250RS but it has two tangs on it. Its a thrust washer and sits next to a needle roller bearing. One tang sits either side of the 'ears' of the circlip and this is what stops it spinning. Might be similar on the 175?
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline RGP750
« Reply #3 on: December 04, 2017, 09:45:54 PM »
Thanks Guys, My thoughts at first but dia is far to great for any of the shafts
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #4 on: December 04, 2017, 10:18:11 PM »
Found it, it is for the crank  ;) https://www.cmsnl.com/honda-cb175k6-super-sport-england_model16498/washer-35mm_90452216000/
I did say it was a bearing retainer ;D ;D
« Last Edit: December 04, 2017, 10:21:28 PM by Trigger »
Offline RGP750
« Reply #5 on: December 05, 2017, 06:56:15 AM »
Well done Trigg Thanks Mate.Mine is obsolete as i have a NOS crank going in with it on .Cheers
More confused now how it got on the bench
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #6 on: December 05, 2017, 07:11:43 AM »
Like everything else on your benches, you put it there  ;D ;D ;D
Offline RGP750
« Reply #7 on: December 05, 2017, 09:12:09 AM »
No doubt, but as the original crank is still in it's bag ??????? :-\
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
« Reply #8 on: December 05, 2017, 11:50:06 AM »
Just remembered Rich ...  when do you need the 175 down-pipes? How did the silencers work out?
« Last Edit: December 05, 2017, 11:57:23 AM by AshimotoK0 »
Offline RGP750
« Reply #9 on: December 05, 2017, 06:52:54 PM »
When you can Ash, Silencers not arrived yet ?????
Thanks to Trigg i can now finish the bottom end ,(when i get time) :(
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
