Author Topic: LED clock lights  (Read 1359 times)
Offline jon stead
LED clock lights
« on: December 07, 2017, 08:08:35 PM »
Changed the clock lights for LED ones. Look the dogs.
Offline Green1
Re: LED clock lights
« Reply #1 on: December 07, 2017, 09:47:24 PM »
That looks snazzy I bet it doesn't look as good in my corroded dented clocks.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline jon stead
« Reply #2 on: December 07, 2017, 10:07:01 PM »
The photo doesn’t do it justice. It looks even better in the flesh
Offline paulbaker1954
« Reply #3 on: December 10, 2017, 08:36:16 AM »
Nice John
Did you find ones that fit in the existing holders or did you do some adaptation
Source would be a help
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline jensen
« Reply #4 on: December 10, 2017, 09:06:14 AM »
Nice, and saves some Watts here and there.
The only issue's with led's is their colour temperature. The colour temperature of the original bulbs is around  2200 to 2700 Kelvin, the modern white led's have generally a colour temperature around 4000 to 5000, and sometimes 6000 Kelvin. In plain English, way to white / blueish. For me, one of the charms of these bikes is the old fashion "warm" white colour of the face plates. The warm white gives me that retro-look when riding it. Next to that, most modern LED's are way too bright.
I was also looking for replacement for my clock lights (for my 1966 CB450) and tried a few before I was satisfied with the result. If one can find LED's with a colour temperature of 2200 to 2700 K for the faceplates you're done, but in most cases, the colour temperature is not mentioned on web-sites or shops (except for head lights and indoor LED replacements).
I found that yellow LED's give almost the same warm light as the old bulbs did. For the neutral I choose amber (if you're  buying green, it's just too green), and orange for the winker indication, or in case of my bomber, for the hi-light.
Jensen
assembly of Japanese motorcycles requires great peace of mind (Pirsig)
« Reply #5 on: December 10, 2017, 11:49:19 AM »
I like that, very cool  8).
Details how you did it please Jon and and materials/suppliers.  I'd like to modify the CB250RS clock lighting if possible.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline jon stead
« Reply #6 on: December 10, 2017, 03:06:35 PM »
Nice John
Sorry, I can’t remember where I bought them, online somewhere, and yes they were just a straight swap for the originals.
Offline jon stead
« Reply #7 on: December 10, 2017, 03:08:29 PM »
Sorry, I don’t recall where I got them but they were a straight swap for the originals.
I’ve attached a picture of the lamp in the reply above.
« Reply #8 on: December 10, 2017, 03:15:02 PM »
How did you wire the indicator light as the indicators change polarity left and right. Therefore the LED should only work on one side as it's a diode that only allows current in one direction?
Offline jon stead
« Reply #9 on: December 10, 2017, 03:49:11 PM »
I’ve only put LED lamps in the speedo and rev counter
« Reply #10 on: December 10, 2017, 04:15:29 PM »
If you wire in two LEDS back to back they'll work in both directions.
« Reply #11 on: December 10, 2017, 04:41:02 PM »
O yeah, why didnt I think of that. Just getting the drill out to make the hole twice the size. ;D ;D
« Reply #12 on: December 10, 2017, 05:29:59 PM »
Roy I must be really dumb but looking at the 500 wiring diagram I don’t for the life of me see how they change polarity can you expand
« Reply #13 on: December 10, 2017, 05:51:38 PM »
The bulbs are a BA9S fitting just look for BA9S LED BULBS on flea bay, there are loads 👍👍
« Reply #14 on: December 10, 2017, 05:55:00 PM »
Perhaps the 500 is wired differently? Would be interesting to test the 500 with a multimeter to see if they do change polarity. The usual way to wire LED's is with a fused direct live feeding into 2* 12v relays, then the indicator connectors 1 to each relay switching the output to the led lamp. A lot of work to just change an indicator repeater bulb to LED. I took mine back out again and re-fitted a standard bulb. Not actually sure why they reverse polarity, like you I couldn't understand from the wiring diagram how it was happening, but it was. Maybe someone like Ash could throw some light on it.
