Author Topic: LED clock lights  (Read 1342 times)
Re: LED clock lights
« Reply #15 on: December 10, 2017, 05:55:00 PM »
Perhaps the 500 is wired differently? Would be interesting to test the 500 with a multimeter to see if they do change polarity. The usual way to wire LED's is with a fused direct live feeding into 2* 12v relays, then the indicator connectors 1 to each relay switching the output to the led lamp. A lot of work to just change an indicator repeater bulb to LED. I took mine back out again and re-fitted a standard bulb. Not actually sure why they reverse polarity, like you I couldn't understand from the wiring diagram how it was happening, but it was. Maybe someone like Ash could throw some light on it.
Offline jon stead
« Reply #16 on: December 10, 2017, 06:25:30 PM »
If you want to use led lamps in the indicators, don’t you just need to change the indicator relay for one that’s suitable for leds?
« Reply #17 on: December 10, 2017, 06:43:44 PM »
Yes, the original type rely on the resistance of the bulbs to discharge a capacitor.
« Reply #18 on: December 10, 2017, 08:34:40 PM »
I'm not making this up, it's very well documented on t'internet. They honestly are opposite polarity.
Offline paulbaker1954
« Reply #19 on: December 11, 2017, 07:01:06 AM »
Roy
I am really interested in this question. I am no electrical guru but I notice the 500 uses a 2 wire flasher relay whilst the 550 uses a 3 wire relay.
Be most interested if someone can clarify this point
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
« Reply #20 on: December 11, 2017, 07:05:43 AM »
Roy
I agree Paul. Been a mystery to me for a while. Some bikes do this and others don't, but tried two of mine CB350F and GS1000 and they both reverse polarity. Jump in anytime you can Ash.
Sent from my Nexus 6 using Tapatalk
« Reply #21 on: December 11, 2017, 07:14:19 AM »
Roy
All the SOHC sub looms have 3 wires for the relay  ;) On the two pin relays you just leave off the ground green wire.
« Reply #22 on: December 11, 2017, 07:28:55 AM »
When I get home tonight I am going to check my CB750 to see if that does the reverse thing as well. Got me re-interested in this again now as I didn't find an answer last time, just took the LED's back out and refitted a bulb.
« Reply #23 on: December 11, 2017, 07:33:02 AM »
Roy
Maybe it's because the CB550 has two idiot lights where the CB500 has only one? Just a guess.
« Reply #24 on: December 11, 2017, 08:10:40 AM »
Relay depends on country, US was 2 wire UK 3 wire, as to the single idiot light on the 500 it don't exactly change polarity, it gets power from the ones that are flashing and grounds via the ones that arnt
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #25 on: December 11, 2017, 09:32:56 AM »
Interesting question! as Trig says all CB's have a 2 wire indicator relay (3rd wire green-earth/ground) I think the answer starts with the orange & sky blue wires from the indicator switch (as image CB750) There are electronic devices to do the job, but not sure as yet, how its done.
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #26 on: December 11, 2017, 01:18:44 PM »
It's done by magic Al, you wouldn't understand.
« Reply #27 on: December 11, 2017, 05:15:42 PM »
Magic indicator LED's...then please 'enlighten'...would be a nice change from the BA9s lamps
Current bikes:-
