Author Topic: oil leak below barrels  (Read 816 times)
Offline billdn
« on: December 26, 2017, 11:54:05 AM »
Not withstanding my cylinder head troubles, my main ride also 400/4, has developed an oil leak below the barrels on the near side front-it seemed to appear after I used an oil flush when doing an oil change. It's not gushing out but weeps slowly and I now have a well oiled left boot. It then runs over the crankcase as the heat and wind disperses it. The big question is it an engine out job ? There is no loss in compression and starts and runs fine, unfortunately the scrutineer at Brands Hatch didn't like it so I couldn't take part in a VJMC parade☹ which is what motivates me to get it done. As far as I'm aware the engines never been out,40 year old nuts and bolts fills me with dread.
Re: oil leak below barrels
« Reply #1 on: December 26, 2017, 12:01:19 PM »
Y remove the head and barrels on a 400 in the frame but first you need to clean it all off and find exactly where the leak is from
Offline ka-ja
  • ken
  • yoshi 460
« Reply #2 on: December 26, 2017, 12:12:42 PM »
It could be running down the cyl. head studs via the head nuts/washers, and showing up at the bottom of the cylinders, but as already said can be done in situ.
nice bike,nothing in the bank
Offline billdn
« Reply #3 on: December 27, 2017, 11:29:08 AM »
Any pointers Ka Ja that might give a clue as to what to look for on cylinder head bolts -I'm guessing perished rubber washers, seals etc.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #4 on: December 27, 2017, 04:41:47 PM »
Original washers were copper coated steel except for the ones fitted under the long head nuts which accept the cover bolts, these had a built in rubber? seal, all the washers were single use only, I use sealant on the washers as new ones are scarce
« Reply #5 on: December 27, 2017, 07:41:11 PM »
Yes, the washers under the long head nuts have Dowty type washers fitted, ie built in rubber washer in the centre of the washer.
Offline billdn
« Reply #6 on: December 28, 2017, 10:25:30 AM »
I know the ones you mean. Mr. Silver has them. Would be nice if that's all but the way my lucks running at the moment I suspect not but changing them wouldn't be a bad idea while I'm doing it.
Offline Dave487
« Reply #7 on: December 29, 2017, 03:57:19 PM »
The copper ones on my engine are pure copper so I annealed them by heating to red hot then plunging in water. It seemed to work ok as I don't have any leaks (yet)
« Reply #8 on: December 29, 2017, 04:07:41 PM »
That's interesting as mine are copper covered steel. I wonder, as yours is an F1 and mine is a F2, if they changed them between models?
« Reply #9 on: December 29, 2017, 04:15:05 PM »
These washers are bloody expensive. For the 10 copper and the 2 Dowty it works out at £46 a set.
Offline ka-ja
  • ken
  • yoshi 460
« Reply #10 on: December 29, 2017, 04:19:25 PM »
I suspect that solid copper washers under the head nuts have been fitted after previous engine work, as the part number for F1 and F2 appears to be the same, maybe something to do with not mixing too many different metals all with different expansion rates
Offline Dave487
« Reply #11 on: December 30, 2017, 05:44:42 PM »
I did buy a couple of new ones from DS because 2 were badly scored and I'm pretty sure they were copper. Anyway Julie if they're copper and in good condition then anneal them if they're steel just use them again. Replace the Dowty seals of course.
