Author Topic: HOW TO MAKE FELT CARB WASHERS  (Read 7027 times)
Re: HOW TO MAKE FELT CARB WASHERS
« Reply #30 on: September 06, 2022, 07:48:05 PM »
Cheers, for that. I have a 26mm and a 20mm hole cutter in the new set. It's better for them to stretch to fit rather than be too big.
Online Bryanj
« Reply #31 on: September 06, 2022, 09:56:18 PM »
Sorry not measured the carb ones yet Ken, had a 15 hour monday night followed by 9hr break so not time ! Have found them so will try tommorrow for you
« Reply #32 on: September 06, 2022, 10:58:38 PM »
No rush Bryan, I know what it feels like to do those hours, you have my sympathies
« Reply #33 on: September 07, 2022, 12:47:54 PM »
Brass bush approx sizes 21 id 25 od but if using brass you dont use the felt, that is only on the original 500 and 750 i think, maybe 450.
All the later onrs use a phenolic top hat type i think
According to CMS the felt washers are used on the CB350F, CB450, CL450, CB500, CB550K and CB750. If I make some I'll bung a few sets on Ebay.
« Reply #34 on: September 07, 2022, 11:18:43 PM »
First attempt.
One problem, whilst I can do a 26 x 20 felt washer quite easily and a 12 x 8 easily I have found I cannot do the small ones for the choke as the cutters for the 10 x 6 that they require both use the same mounting position so I cannot cut them both at the same time, unlike the others. Plus after checking a 500 carb body it would appear that the 500 is the same size as the 400, the problem is 9mm is too small and 9.5mm is fractionally too big. The shaft is 6.8mm. There are no 9mm cutters in the set.
Looks like I'm going to need to get creative.
A swinging arm washer and 2 lifter washers. I didn't hammer hard enough for the swinging arm one, hence why it's a little fuzzy on the inside edge. They do seem a lot more robust than the previous ones I made by hand.
« Reply #35 on: September 08, 2022, 08:31:12 AM »
Dogs bollocks.👍
« Reply #36 on: September 08, 2022, 07:44:07 PM »
Funny that, Its where they get the felt from................truestory, it's a thing you know. ;)
« Reply #37 on: September 09, 2022, 07:58:24 AM »
Synthetic dogs bollocks!
« Reply #38 on: September 09, 2022, 12:41:19 PM »
Hey, I inadvertently made a Mickey Mouse figure  ;D ;D
Online Bryanj
« Reply #39 on: September 09, 2022, 12:58:18 PM »
Sure its not Minnie?
« Reply #40 on: September 09, 2022, 12:59:05 PM »
No breasticles Bryan.
« Reply #41 on: September 09, 2022, 11:59:57 PM »
Offline Matt_Harrington
« Reply #42 on: October 20, 2022, 03:46:20 PM »
I now have most of the bits together to rebuild my 400/4 carbs. Could someone clarify the size of the felt washers for me?
« Reply #43 on: October 20, 2022, 04:01:57 PM »
12 x 8 for the lifter spindle, the choke ones are very hard to make, I seem to recall 10 x 6.9,  Bryan tested the ones I made and said the attrition rate was around 50%, that may be because he was the first to test them and maybe they'd be better once you knew exactly how to fit them. I'll have a try on a set of 500 carbs and see how I do.
Online Bryanj
« Reply #44 on: October 20, 2022, 04:47:06 PM »
I think if the felts were soalked in oil for some time they may hold together better, the originals seem to be a denser felt
