Author Topic: Checking Stator  (Read 662 times)
Offline Integra99
Checking Stator
« on: February 02, 2018, 10:23:01 AM »
Hi guys.. can anyone help me with how to check my stator is working.
I've hooked up the new reg/rect and I'm getting about 12.75 up to 13v with a few revs so no where near enough.
Is there a way to check the yellow wires.. are making a current as its seems I'm down a little.. many thanks!
Re: Checking Stator
« Reply #1 on: February 02, 2018, 11:14:27 AM »
Hi,
      Get a multi meter and check the yellow wires individually to ground, there should be no continuity.
Also check the yellow wires to each other in pairs.
I do have a guide to all this somewhere I will see if I can find it out.
« Last Edit: February 02, 2018, 11:17:30 AM by paul G »
Honda CB400 4
Honda CB550 K3 (sold)
Honda CB750 UK K1
Re: Checking Stator
« Reply #2 on: February 02, 2018, 11:21:36 AM »
These may help
Honda CB400 4
Honda CB750 UK K1
Re: Checking Stator
« Reply #3 on: February 02, 2018, 11:22:39 AM »
These may help
« Last Edit: February 02, 2018, 11:32:21 AM by paul G »
Honda CB400 4
Honda CB750 UK K1
Offline Integra99
Re: Checking Stator
« Reply #4 on: February 02, 2018, 12:14:11 PM »
Thanks Paul, most helpful I will print these out.. without sounding useless how do you use the multimeter to test the yellow stator wires for resistance?
Just a thought I'm running 3 ohm coils.. with the increased resistance could this affect my charge rate?  I plan to fit Dyna k ignition but assumed it would be ok.
Re: Checking Stator
« Reply #5 on: February 02, 2018, 12:30:12 PM »
Set it on Ohms Ω
Honda CB400 4
Honda CB750 UK K1
Re: Checking Stator
« Reply #6 on: February 02, 2018, 01:09:56 PM »
It is rare for the stator of field coil to fail electrically, only through physical damage. most common cause of undercharge is corroded connectors
Offline Integra99
Re: Checking Stator
« Reply #7 on: February 02, 2018, 02:04:16 PM »
Thanks guys.. it was working before, suspect must be a dodgy connection but want to run through the system.
So with the meter on ohms to do a continuity test I pop one lead on the yellow stator and then the other on a field coil wire.. is that correct. I apologise if a stupid question I am leaning each problem.
Re: Checking Stator
« Reply #8 on: February 02, 2018, 02:24:05 PM »
Nope, one wire on a yellow wire and the other on the casing to check insulation then there are 3 "pairs" of yellow wires and you check across each pair. For the field check between the wires and also either wire to casing
Re: Checking Stator
« Reply #9 on: February 02, 2018, 02:40:40 PM »
V.   Testing the stator yellow leads.
A.   Test wires 1 and 2, 1 and 3, 3 and 2 for ohm readings.  Less than 1 ohm means the circuit is good.  Greater than 1 ohm means poor connection.  Infinite resistance means that the coil has an open circuit or possibly a bad lead.
B.   NOTE.  For GL1000 you need to disconnect/remove the permanent magnet rotor before continuing.  Set tester to insulation resistance and calibrate it to 0 to perform a wire insulation test on the stator.  Ground the negative test lead and touch the other lead to each of the three stator wires.  If the resistance is infinite then the coil is ok.  If not then the coil is shorted to ground.
C.   Test the three stator wires in the harness of the motorcycle.  First disconnect the rectifier.  Set the tester to resistance.  0 resistance means all three wires are fine.  Greater than 0 means the wire is bad.
D.   Check the wires for bad insulation.  Connect the black tester lead to ground.  Each wire should have infinite resistance.  Greater than infinite resistance means the wire has bad insulation.
Honda CB400 4
Honda CB750 UK K1
Offline Integra99
Re: Checking Stator
« Reply #10 on: February 02, 2018, 04:11:14 PM »
Thank you.. I will run through this over the weekend.
Offline SteveW
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline Integra99
Re: Checking Stator
« Reply #12 on: February 05, 2018, 09:43:00 AM »
Great read cheers..
Looks the the stator coil is done.. new one ordered today!"
