Author Topic: F2 Camshaft Towers  (Read 689 times)
Offline neilg
F2 Camshaft Towers
« on: February 03, 2018, 10:21:50 AM »
I am using an F2 top end on my latest. The head I have has 8 studs to support the camshaft towers. The parts lists show the usual mix of 4 studs and nuts and 4 bolts. Has any one any idea if this is a later factory change or is it something that has been modified by a previous owner. Any thoughts?
Offline UK Pete
Re: F2 Camshaft Towers
« Reply #1 on: February 03, 2018, 10:29:07 AM »
Post a pic
Offline neilg
« Reply #2 on: February 03, 2018, 11:48:19 AM »
The studs are being used for the four caps. Bolts are still used on the center fastenings, they look factory but I've never seen studs used on all four cap fasteners and would like to know whether to leave or swop them.
« Last Edit: February 03, 2018, 02:38:27 PM by neilg »
« Reply #3 on: February 03, 2018, 06:06:04 PM »
The Honda manual for F3 version (runout model of F2 for USA) shows studs for front / exhaust side of head and bolts for rear / carb side of head.
I suppose it's possible the pictures in manual didn't keep up but suggests that they're the same as all the others in the info I've got.
Offline r1_pete
« Reply #4 on: February 04, 2018, 08:15:20 PM »
From an engineering viewpoint studs are a better solution, less chance of stripping the threads in the alloy head.
It could be someone has stripped one or more, and put studs in to reach undamaged threads deeper in the hole..
2009 Yamaha XJR1300 sold
1977 CB750F2 café racer project. Sold
1972 CB750K2 hot rod. Sold
and an E-Type Jaguar that considers itself worthy of all my spare cash. Sold
1971 CB450
1978 Reliant Scimitar Cosworth.
Offline neilg
« Reply #5 on: February 05, 2018, 01:21:56 PM »
Thanks for your thoughts. I also looked at the F3 thinking that perhaps it was a later mod brought on by F2isms. At the moment I'm inclined to agree with Pete and will probably leave well alone unless anyone has any other ideas or has come across this. Like most on here with F2 experience I'm well aware of the failings and it does seem like a logical mod which is what led to think it might have been from the factory.
