Author Topic: Pin removal  (Read 692 times)
Offline Deano400
Pin removal
« on: February 11, 2018, 03:39:17 PM »
I could do with some advice on removing a pin from the crankcase. The pin is near enough flush with the case and I can't get any real grip on it. Looks like the engine was built (maybe rebuilt) with the bearing not in the right position so pin is jammed in, bearing is shattered (still runs smooth though). New pin required, was going to change all bearings anyway.
Re: Pin removal
« Reply #1 on: February 11, 2018, 03:49:33 PM »
Plenty of heat, turn case upside down and hit with appropriate hammer, it may fall out. Or, spot weld a bolt to it and remove it that way. Someone may have fitted the wrong size pin in there, check to be  sure case isn't fractured the other side of pin.
Offline Deano400
Re: Pin removal
« Reply #2 on: February 11, 2018, 03:53:59 PM »
Thanks Julie. I think I'll try the heat first, I'm not the best welder and am worried I'll do damage to the case.
Re: Pin removal
« Reply #3 on: February 11, 2018, 04:01:22 PM »
Heat is worth a try as even if the pin doesn't come out all the way, it may move enough for you it get some grips on. That bearing looks interesting  ;D ;D. I only had to change one bearing on my rebuild, the clutch lifter bearing as although still functioning well, sounded crunchy. Bearings don't usually need changing, unless broken like yours but if you do go that route, buy the best bearings you can, cheap ones are a false economy. I think a full bearing kit for our bikes is about £130.
Offline Deano400
Re: Pin removal
« Reply #4 on: February 11, 2018, 04:09:57 PM »
I think I'll check the other bearings and hopefully they'll be ok. If so the £130 can go into my re-chroming pot. :) :) Thanks.
Offline Green1
Re: Pin removal
« Reply #5 on: February 11, 2018, 05:52:15 PM »
Would that be the pink claw hammer Julie  ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Re: Pin removal
« Reply #6 on: February 11, 2018, 06:40:31 PM »
You know me too well Mick  ;D ;D [ Guests cannot view attachments ]
Re: Pin removal
« Reply #7 on: February 11, 2018, 10:03:20 PM »
Dremel a slot in it and use a screwdriver to loosen it.
Offline Seabeowner
Re: Pin removal
« Reply #8 on: February 11, 2018, 10:17:06 PM »
Think yourself lucky the pin went in and didn't crack the casings.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Re: Pin removal
« Reply #9 on: February 12, 2018, 10:25:41 AM »
Good idea Mike. I think I would combine the two options at the same time, the slot with a bit of heat.
Have a bottle of beer at the ready to drink in celebration when the pin comes out  :).
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
Offline Deano400
Re: Pin removal
« Reply #10 on: February 12, 2018, 11:57:22 AM »
Thanks all for your replies. Have taken a closer picture showing more detail.
Julie, thanks for pm. I think the bit you were talking about was a piece of the bearing shell.
Offline Deano400
Re: Pin removal
« Reply #11 on: February 12, 2018, 11:58:45 AM »
The other one looks ok but I am surprised at how little the pin sticks out.
