Author Topic: Unlocking the seat  (Read 694 times)
Offline garyb163
Unlocking the seat
« on: February 12, 2018, 03:46:58 PM »
Hi guys, My CB550F2 1977 only has one key. It operates the ignition and the fuel filler flap but it won't open the lock to gain access to the under seat any ideas as to how I can gain access?
Offline SteveW
Re: Unlocking the seat
« Reply #1 on: February 12, 2018, 04:54:55 PM »
Just had a look at mine (74 K0).
You wont be able to get at the lock easily as its bolted to the frame under the seat.
What might be possible is if you feel upwards towards the seat, either side of the seat plunger that engages with the lock there are 2 10mm nuts that bolt the plunger to the seat. I think with a small ratchet you can get at them.
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Offline garyb163
« Reply #2 on: February 12, 2018, 06:07:40 PM »
Thanks SteveW I'll give that a go tonight.
Offline petermigreen
« Reply #3 on: February 12, 2018, 06:30:10 PM »
Does the seat lock not have a number on it? Usually a 4 digit number adjacent to the key slot. If it does you can either confirm it's the same as the other locks or order the correct one.
Peter
Offline garyb163
« Reply #4 on: February 12, 2018, 08:12:38 PM »
Hi Petermigreen, I've checked and there are definitely no numbers on the lock or any where near it. The one key I have fits both the ignition and fuel cap locks. The same key fits in the seat lock barrel but won't turn. Do you think as I do that some one at some stage has fitted a new seat lock? If so I wonder why?
« Reply #5 on: February 13, 2018, 06:53:09 AM »
More likely a new ignition switch, any key(including a screwdriver) will open the fuel cap lock
