Author Topic: Strobe timing light.  (Read 1698 times)
« on: March 09, 2018, 06:34:21 PM »
As my POS timing light has decided to be working sometimes and sometimes not, I need a replacement of good quality. Am looking at one of these  https://www.ebay.co.uk/itm/SP8000-Ignition-Timing-strobe-Lamp-light-with-digital-advance-and-Rev-counter/182940061390?epid=12002713091&hash=item2a9813cece:g:amcAAOSwgY9Xc5ih
Anybody used one, are they worth the money. Cheers all.
Re: Strobe timing light.
« Reply #1 on: March 09, 2018, 07:51:40 PM »
Be aware the rec counter wont be accurate and not sure about the digital timing
« Reply #2 on: March 09, 2018, 07:54:12 PM »
That is toooo much £££ for a strobe light. I am sure the last time I was visiting Watford classic cars, that they had them for less than a 20 pound note  ;)
« Reply #3 on: March 09, 2018, 08:03:10 PM »
I have one similar,but not with rev counter and advance gadget
 it has a bright light ,can see the making on the Honda
« Reply #4 on: March 09, 2018, 09:25:04 PM »
I bought the basic model of that make - never worked! Need one myself shortly when I buy my electronic ignition
Offline ka-ja
  • ken
  • yoshi 460
« Reply #5 on: March 10, 2018, 09:17:22 AM »
Hi All,
           I too bought the cheaper version, basically dead as a do-do from day one, a few odd flashes when turning the engine over, dead once  started.
nice bike,nothing in the bank
« Reply #6 on: March 10, 2018, 09:31:06 AM »
I guess I wont be buying that then..... Any recommends for a good make and model, it appears to be the inductive pickup that's the problem with a lot of these strobes?....... What make is that sub £20 one Trig.
« Reply #7 on: March 10, 2018, 10:24:33 AM »
This is the one I use Roy, works a treat.
1976 Honda 400/4
1978 Honda CB400/4 'Rat' bike
1976 Honda 400/4
« Reply #9 on: March 10, 2018, 12:07:46 PM »
tut, forgot the link, senior moment ::)
https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiLsq3wxOHZAhXMu-0KHZCnAvMYABAIGgJkZw&ohost=www.google.co.uk&cid=CAASE-RoTsyD4eHTEyFFGpr98cEd_3w&sig=AOD64_2JGQUE9D7gMe4ssiHvi2fHZnGrlg&ctype=5&q=&ved=0ahUKEwjE1anwxOHZAhUrC8AKHQ9eAswQ9aACCDE&adurl=
Strangely that's the very one I am replacing. Works about 1 in 3 flashes and sometimes not at all. When the engines revving away merrily to strobe electronic ignition the last thing you need is an iffy strobe lamp. The CB350F boyer ignition has to be strobed at 5000rpm, and the GS1000 at 2500rpm so it's best to get a move on.
« Reply #10 on: March 10, 2018, 02:43:29 PM »
I have my original strobe I had from the early 70s that was used in series in HT circuit - still works but not very clear strobe image ((I'm not as clear as I was in the early 70s!) - can you still get that type as not sure if it's the clip on HT lead connection that's the issue with the intermittent strobe image?
Sent from my Moto G (5) using Tapatalk
Offline tom400f
« Reply #11 on: March 10, 2018, 03:41:13 PM »
As they say in Private Eye - WELL FANCY THAT!
I've just fitted the Newtronic ignition I bought from Trevor (firet49) so I bought this one.
It was £12.95 +£4.95 postage when I got it and the £19.95 postage in the current listing I assume is incorrect. Anyway, it works OK. Pick up is a little sensitive but I managed to get a good strobe even on 2/3.
I think it's one up from the cheapest. Does one need a rev-counter? F mark lines up when idle, advance mark lines up at 3k. Do we need  more? Won't see much use in my case.
Electronic ignition itself seems great. I know people say points will never let you down etc etc, but, really, fed up with always fiddling with it  ...  ???
1978 CB400F2 Yellow
1995 VFR750FS Red
1997 VFR750FV Lapis Blue
2013 Yamaha FZ8 Grey
Offline kevski
« Reply #12 on: March 10, 2018, 06:01:56 PM »
I have the accuspark 8000 and it does the job perfectly well, as for points and condensers when mine start to get a bit naff on the 350 it will be electronic ignition straight away, can't be doing with any faffing around, and as buying points and condensers is a bit like an unlucky dip where quality is concerned now, i would rather have the modern reliability of electronic ignition.
Offline tom400f
« Reply #13 on: March 11, 2018, 09:51:56 AM »
Indeed. This looks like the best deal out there:
https://www.ebay.co.uk/itm/AccuSpark-Professional-S8000-Ignition-Strobe-Timing-Lamp-Light-/331737007734?hash=item4d3d110676
1978 CB400F2 Yellow
1995 VFR750FS Red
« Reply #14 on: March 11, 2018, 11:13:38 AM »
Looking at comments made elsewhere about this strobe, it still has the same problems as others mainly the inductive pickup can be very hit and miss. This is the same problem that I have with my existing Draper unit. Makes an easy 5 minute job into half an hour of frustrating fiddling. Have now bought a secondhand Gunson strobe that the reviews say has a rock solid pickup. When I get it, I will report back how good (or crap) it is. Same as this one but better condition   https://www.ebay.co.uk/itm/GUNSONS-12-V-DC-TIMESTROBE-XENON-TIMING-LIGHT-AND-INDUCTIVE-PICK-UP/382399864099?hash=item5908cedd23:g:UF0AAOSwnHZYl0MQ
« Last Edit: March 11, 2018, 11:16:08 AM by royhall »
