Author Topic: CB400f - Magnetic Coil  (Read 661 times)
Offline Integra99
« on: March 16, 2018, 08:45:45 AM »
Well the CB400f has taken a back seat as I cannot get it to charge.. so after 12 months work I've set it aside for a couple of weeks as worn out.. I can see how people lose interest at 99% complete of a build!
So finally pulled into the workshop, everything checks out and appears as it should. Apart from the Rotor.. it doesnt seem to be magnetised.. which must have an effect. it was working before the strip down.. stator all ok.
Any ideas why this may be the case? I've never seen this before.
Offline ka-ja
  • ken
  • yoshi 460
Re: CB400f - Magnetic Coil
« Reply #1 on: March 16, 2018, 09:42:37 AM »
The rotor 's magnetism is generated by the center coils receiving voltage via the regulator when the engine starts up
nice bike,nothing in the bank
« Reply #2 on: March 16, 2018, 10:33:46 AM »
99.99% of charging faults are loose/corroded connections or a sticky reg
Offline Integra99
« Reply #3 on: March 16, 2018, 10:38:16 AM »
Thanks I have a spare centre coil I'll try that
Offline ka-ja
  • ken
  • yoshi 460
« Reply #4 on: March 16, 2018, 08:08:56 PM »
Hi,
     there should be about 4.9 ohms between the two wires (white + green), but as Bryanj has suggested, connectors and the regulator are highly suspect on older machines
Offline SteveW
1974 CB550 K0
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
