Author Topic: Bizarre rev counter problem  (Read 1621 times)
Offline kent400
Re: Bizarre rev counter problem
« Reply #15 on: April 07, 2018, 08:44:23 PM »
The gauges need to flexible within their mounting plates so using the correct length distance pieces on the gauge studs and the correct washers under the cap nuts is important. Drawing the gauge too far in the plates compress the foam cushions too much and defeats their purpose.  I'll have some of those distance pieces in the spare box, they often drop out when the gauge is removed and roll away into some dark corner never to be seen again.
Offline Seabeowner
« Reply #16 on: April 19, 2018, 05:09:55 PM »
Thanks for that info Peter and an update.
I think I have the correct spacers (7.1mm) in there, but I have tried inverting the stepped rubber washers and putting then in the holder from the top. Tried this loose with good results and will try with an additional rubber washer on the outside. But much improve.
Paul, I see you have additional thoughts on your mind (exhausts) and I will be following that with interest as I have been running a set of the repros from DSS for a year.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
Offline kent400
« Reply #17 on: April 19, 2018, 06:23:44 PM »
That's the correct size spacers and the washers on the top of the should be 2 mm.
Offline thegreatpan
« Reply #18 on: April 21, 2018, 06:07:57 AM »
I have the sticky tacho problem on the 400, does anyone offer a gauge refurb service?
« Reply #19 on: April 21, 2018, 07:53:04 AM »
Yes, Kent400 (Peter) refurbs them.
Offline thegreatpan
« Reply #20 on: April 21, 2018, 09:08:46 PM »
Thanks Julie
