Author Topic: CB500F2 Cam Chain Adjustment  (Read 2799 times)
Offline Dave M
« on: July 23, 2007, 02:43:17 PM »
Hi, newbie here!
It's a few years since I had my CB750 and I'm hoping to collect my 1978 CB550F2 on Sunday.
I had a test ride yesterday and the carbs need balancing and the cam chain is rattling quietly.
I've not got a manual yet so could some kind person remind me how to tension the cam chain.
I've had a quick look and on the back of the block at the bottom there's a locknut and screw and further up there's a bolt.
I seem to remember the engine is set to 15 degrees after TDC but not sure what to do with the bolts.
Many thanks.
Dave
Melbourne.
Offline dave400
Re: CB500F2 Cam Chain Adjustment
« Reply #1 on: July 23, 2007, 05:15:45 PM »
Dave, if nobody with a 550 tells you the procedure I
« Last Edit: July 23, 2007, 06:08:57 PM by biffta »
Offline Dave M
« Reply #2 on: July 24, 2007, 07:33:23 AM »
Thanks Dave.
Seems very easy. Keep you posted.
Dave
Melbourne.
Offline Dave M
« Reply #3 on: July 29, 2007, 06:21:49 PM »
Right.
I loosened the locknut as instructed but the bolt turned as well. I can't get a screwdriver on the slot either.
I've looked at the manual and can't see how the tensioner actually works. Does it matter that the bolt turns with the nut?
Dave
Melbourne.
Offline Dave M
« Reply #4 on: August 02, 2007, 11:54:53 AM »
Sorted!
I kept turning the nut and after about half a turn the setscrew stopped turning and the the nut loosened. The setscrew was nice and loose as well.
Nipped it back up again and started the engine. As quiet as a 15k mile motor should sound!
Well pleased.
Dave
Melbourne.
