Author Topic: 750 K1 project  (Read 22955 times)
Offline Crispy
Re: 750 K1 project
« Reply #60 on: May 14, 2018, 07:07:12 PM »
Not checked my main bearings yet..still waiting for some plastigauge to arrive but judging by the wear and tear so far I'm expecting to have to put new ones in..so have been getting my head around the method of selecting the bearings this afternoon...not straightforward..like go out and buy a 6304 bearing is it?  Think I've Sussed  it....written them down below...any tips on where is the best place to get them if needed, also need to get full gasket , oil seals and o ring set?
Ps the upside down picture thing is something to do with my iPad, only occurs with pics taken with that...nobody else suffer from this?
« Last Edit: May 14, 2018, 07:23:52 PM by Crispy »
Offline Crispy
Re: 750 K1 project
« Reply #61 on: May 15, 2018, 07:32:28 AM »
Just realised David Silvers has the bearings..thought they would be harder to find 🙄
Offline Crispy
Re: 750 K1 project
« Reply #62 on: May 20, 2018, 05:17:24 PM »
Measured the bearing clearances today...I'm thinking that these bearings will be ok  to re-use....I get a clearance of 0.050mm and the limit according to the manual is 0.080mm....However the manual also states that the standard clearance should be 0.02 to 0 046mm. Should I replace them anyway?
Re: 750 K1 project
« Reply #63 on: May 20, 2018, 07:05:14 PM »
To get that reading, have you torqued the crank up.
Bearings can be a bit funny, some of the gearbox bearings are under licence to Honda only.
« Last Edit: May 20, 2018, 07:09:13 PM by Trigger »
Offline Crispy
Re: 750 K1 project
« Reply #64 on: May 20, 2018, 07:18:19 PM »
Yes..torqued it up as per the manual!
Re: 750 K1 project
« Reply #65 on: May 20, 2018, 07:24:06 PM »
Well, your plasti strip is a lot cleaner than mine  ;D ;D
Offline Crispy
Re: 750 K1 project
« Reply #66 on: May 20, 2018, 07:29:05 PM »
Well I've only used it once!... Bet yours has been put to more frequent use!
Re: 750 K1 project
« Reply #67 on: May 20, 2018, 07:32:30 PM »
I would go with those shells. Is the oil pump apart yet ? If the oil pump is at full pressure, the shells are fine.
Offline Crispy
Re: 750 K1 project
« Reply #68 on: May 20, 2018, 07:39:47 PM »
Cool ...No..I haven't touched the pump yet 😬  Will do at some point though !
I'll also repeat the plastigauge measurements a couple more times just to see if I can repeat the same results.
« Last Edit: May 20, 2018, 07:45:43 PM by Crispy »
Offline Crispy
Re: 750 K1 project
« Reply #69 on: June 03, 2018, 08:14:32 PM »
Engine cases painted and cured, I can now begin to re assemble the engine.  After reading older threads I'm thinking I will get the Vesrah gasket set and Honda head gasket, unless anyone has any other advice.? I am also replacing the primary and cam chains, again any advice re primary chains ? Getting the upgraded did chain ....part number ....219FTH 94LE ..which I've just spotted on another recent thread... Cheers Trigger 👍
« Last Edit: June 03, 2018, 09:00:24 PM by Crispy »
Re: 750 K1 project
« Reply #70 on: June 03, 2018, 09:03:13 PM »
Looks nice, what paint was used ? Use the STD primary chains. Vesrah are the best available.  Not sure if anyone in the UK does the upgraded cam chains, seems to be a lot of old stock ones floating about. If you get stuck for one, I can supply you one  ;)
Offline Crispy
Re: 750 K1 project
« Reply #71 on: June 03, 2018, 10:20:12 PM »
Cheers Trigger,
Used Simoniz VHT31C engine enamel, may be in touch re cam chain! 👍
Offline Crispy
Re: 750 K1 project
« Reply #72 on: June 08, 2018, 06:51:09 PM »
Got some nice shiny fork bits back from Philpotts today! 😊 Here are a few before and after pics..
« Last Edit: June 08, 2018, 07:20:42 PM by Crispy »
Re: 750 K1 project
« Reply #73 on: June 08, 2018, 07:13:03 PM »
Lovely work from Philpotts there..
Re: 750 K1 project
« Reply #74 on: June 08, 2018, 07:45:23 PM »
Lovely shiney blingy bits there. Very nice. Did they polish the fork lowers you?
