Author Topic: Rear wheel lock washer  (Read 598 times)
Offline sgd37
« on: April 05, 2018, 12:43:20 PM »
Hi everyone,
Does anyone know what I could replace the stock lock washers on the rear wheel with? Maybe I'm being picky but they look like they need a change.
Re: Rear wheel lock washer
« Reply #1 on: April 05, 2018, 09:00:59 PM »
Hi everyone,
Are you on about the sprocket locking washers PN  90524-323-000 ?
Offline sgd37
« Reply #2 on: April 05, 2018, 11:13:22 PM »
Yeah they're the ones.
Sorry I should have been more specific
« Reply #3 on: April 06, 2018, 07:58:31 AM »
Loctite.
« Reply #4 on: April 06, 2018, 08:00:33 AM »
They are always a bit tatty after a while but, if they are doing the job, leave them alone. New ones are about a couple of quid each. Later Hondas did not even use them, they just superseded the nuts to a flange type.
Offline Seabeowner
« Reply #5 on: April 06, 2018, 09:50:58 AM »
What's the view of the MOT testers here to delta's suggestion on Loctite, As this is not an obvious indication.
As said later models dropped the lock washers on the rear sprocket and the front disc, but that was using flanged nuts and an observable change.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
1978  CB550K     Excel Black
« Reply #6 on: April 06, 2018, 10:01:03 AM »
From memory if a lock washer is there it must be used correctly and complete, if not there the nut must be there and not be visibly loose---you are not allowed any tools to check tightness, only fingers. Split pins or "R" clips are a different matter, i think the wording is if possible to be fitted then must be
Offline sgd37
« Reply #7 on: April 06, 2018, 06:53:22 PM »
I would leave them as is however I had to take them off anyway so I'm guessing bending them back wouldn't be ideal.
Could I get away with serated flanged nuts then like the later hondas? Or would toothed lock washers be better
