Author Topic: cb400F stator coil wiring  (Read 474 times)
Offline llessur
  • Honda 400/4
« on: April 14, 2018, 12:50:23 PM »
From the stator coil to the small harness are three yellow wires. If I understand the way it works correctly I do not think it matters which yellow wires (bullet connectors) go to which yellow wires on the small harness. Before I go and do any damage I wondered if someone in the know would mind either confirming this or setting me on the right track.
As always, thank you
Re: cb400F stator coil wiring
« Reply #1 on: April 14, 2018, 12:58:46 PM »
That's correct.  :)
Offline llessur
  • Honda 400/4
« Reply #2 on: April 14, 2018, 01:02:02 PM »
thank you so much
...........on with the build  :)
