Author Topic: Odd sounding number 1 exhaust  (Read 483 times)
Offline paulbaker1954
« on: April 18, 2018, 06:57:03 PM »
Hi
My number 1 exhaust is making not the usual sound after the winter lay up
It sounds a bit like a boom boom noise and if you hold your hand over the end of the pipe it feels as if the pressure is higher than the othe 3 cylinders
Not sure if I need to worry as the bike runs fine other than that and pulls well through rev range just this odd noise at tick over
Any ideas ?
I guess I could post a vid on you tube if needed but not at home at the mo
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Odd sounding number 1 exhaust
« Reply #1 on: April 18, 2018, 08:07:54 PM »
   is the rubber tube link OK?
  not leaking
« Reply #2 on: April 18, 2018, 08:17:30 PM »
Internal baffling breaking up or rusted loose? Less baffling equals less restrictive path for exhaust gases, therefore would have more pressure at tail end.
« Reply #3 on: April 18, 2018, 08:24:30 PM »
Had a rattle from the inner down pipe that rusted at the top once. Took yonks to find that problem ;)
« Reply #4 on: April 18, 2018, 10:46:03 PM »
Interesting but these are only 2 year old CMSNL pipes
« Reply #5 on: April 19, 2018, 05:52:23 AM »
The original Honda made ones they came with new, some were having to be replaced under warranty in less than 6 months as they rotted so quickly, so don't ever assume that a fairly new or even brand new part cannot be at fault!
« Reply #6 on: April 19, 2018, 07:23:03 AM »
Dumb ? but is there a way to check/test these DS/CMS Pipes as I don’t think the baffles are removable
« Reply #7 on: April 19, 2018, 07:29:12 AM »
Tap gentlyish with soft objet to see if it rattles
