Author Topic: Compression test levels  (Read 443 times)
Offline paulbaker1954
« on: April 26, 2018, 06:11:14 PM »
Just been doing some more investigating on my odd sounding no 1 cylinder and decided to check compression. I am getting 135 psi on all 4 pots so no drastic difference on no 1 cylinder
That said are these readings a bit on the low side as the maintenance manual mention 177 psi
I should add that engine had a full rebuild 2k miles ago with new pistons and rings and I also regrouped all valves in etc
I should add that this was a “dry” test ie no oil put down bores etc
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Re: Compression test levels
« Reply #1 on: April 26, 2018, 06:30:40 PM »
Did you have the throttles wide open and a warm engine?
« Reply #2 on: April 26, 2018, 07:28:57 PM »
Should have said
Throttles and choke open on cold engine, would a warm engine make that much difference
« Last Edit: April 27, 2018, 07:29:15 AM by paulbaker1954 »
