Author Topic: Master Cylinder question  (Read 569 times)
Offline sprinta
« on: April 30, 2018, 03:03:25 PM »
Can anybody advise what the smaller hole diameter is inside the fluid chamber?
Just had the M/C re-anodized and there was a bit of crud from the process in the hole. Have passed a 0.5mm drill by hand through it but wondered if I need to pass a larger drill through it?
Andy
Offline Green1
Re: Master Cylinder question
« Reply #1 on: April 30, 2018, 07:31:18 PM »
Couldn't tell you. But I shouldn't think giving the drill bit a gentle wiggle would hurt.
How hard can the crud be?
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Mr_Sheene
« Reply #2 on: May 01, 2018, 11:06:17 AM »
It's the Vent Port/By-Pass Port. The piston can't return correctly without it, so you do need it. It should not be enlarged. It's there to allow equilibrium.
Please have a look at have a look at
https://www.freeasestudyguides.com/brake-master-replenishing-port.html
This explains it better than I can.
Also, when you rebuild the M/C, make sure that the port is not blocked inside, by the positioning of the piston/seals.
I know this because I once thought that I was so clever that I could improve the brakes on my R90S. I was wrong - not for the first time!
Offline Green1
« Reply #3 on: May 01, 2018, 06:11:17 PM »
Should have said gentle wiggle to remove crud not to enlarge the hole.
Not once have I ever thought about drilling it out.
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
Offline sprinta
« Reply #4 on: May 01, 2018, 07:29:46 PM »
Thanks for the replies and advice. It was because of being conscious of not enlarging the hole that  I did not want to pass anything too large through it, hence try to establish it's normal dia.
Have used the 0.5mm drill, which I am sure is smaller and a syringe with some alcohol which will have hopefully cleaned the crud out.
Andy
