Author Topic: 400 into 350 swap?  (Read 472 times)
Offline gtmdriver
400 into 350 swap?
« on: April 30, 2018, 04:50:59 PM »
I have a CB350F with a tired engine. There is a lot of blowby and crankcase pressurisation.
I want to rebuild the 350 engine but here in the UK spares are rare and it make take some time.
To avoid the bike being off the road I would like to temporarily fit the complete engine from a CB400F.
Apart from the clutch operation are there any other differences?
My bike has the full 4 pipe system. Will that couple up to the engine OK?
Offline Orcade-Ian
    • Older Vehicle Web
Re: 400 into 350 swap?
« Reply #1 on: April 30, 2018, 06:06:44 PM »
I have both the 350 and 400, as you say the clutch operation is different but as mainframes are the same, I can’t see why you can’t couple the cable in the normal way- you might have a problem with cable lengths though.  The 400 clutch cover doesn’t fit the 350 cases but you don’t need to change any of that.  The gearchange is different and 6 speed on the 400.  Not near my bikes till tomorrow but I have a feeling the 350 lever works t’other way - I’ll check.  As the stroke length is the same on both and only the bores are different, I would guess that the pipes would fit without drama.
Can’t think of any other problems you might meet.
Ian
Just spotted that was post 333 for me - spooky, that’s the model number of the CB350F -  Off to buy a lottery ticket🤓
« Last Edit: April 30, 2018, 07:13:11 PM by orcadian »
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #2 on: May 01, 2018, 09:44:12 AM »
I was wrong (again) the gear-lever has a linkage on the 400 but straight on the shaft on the 350, so that will not be a problem.  Difficult to measure accurately but the exhaust ports are close to the same height from the lower frame rails on both bikes - go for it!
Ian
Offline gtmdriver
« Reply #3 on: May 01, 2018, 12:43:59 PM »
Thanks for that.
On the US site they talk about footrests kickstarter and brake lever too but nothing insurmountable.
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #4 on: May 01, 2018, 05:10:34 PM »
Yes the 400 footrests are different but you are using the 350 pegs so if you fit the 350 gear-lever to the 400 box, I can’t see a problem. The only issue might be that your right hand 350 footpeg might be too close to the 400 clutch cover - might need a spacer and longer through-bolt.  Kick start shouldn’t be a problem as your footrest is in front of it rather than behind.  Brake lever is already longer to match up with the footrest.
Ian
