Author Topic: Beware non original CB750 side panel grommets  (Read 385 times)
Online martin_uk
« on: May 12, 2018, 10:56:32 AM »
I found this issue and wanted to warn others.
I managed to fit one non standard grommets when restoring my K8.
I was trying to remove the side panel and other two lugs came out but one resisted all attempts inc use of WD40.
I applied a bit of leverage but panel cracked >:(
My own fault but annoying with a pristine painted panel.
I did manage to remove using a hot air gun to warm grommet as it had gone very hard.
Should have done this first.
I have replaced grommet with a new Honda item.
Decided to have a bit of a clear out and the K8 and C90 are first to go.
I have a CB750 F1 restored to rolling frame, ideal if someone has a good engine.
Just got fresh MOTs on both.
I have got quite a few 400/4 bits as well and will try to get a list and photos together
« Last Edit: May 12, 2018, 11:26:06 AM by martin_uk »
1977 CB750F1
1977 CB750f1 836
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Honda CB500X
BSA WD B40 350
Offline RGP750
Re: Beware non original CB750 side panel grommets
« Reply #1 on: May 12, 2018, 06:24:30 PM »
Hi Martin
I have a guy restoring a 400 who works for me, may be interested in any 400 stuff .
Thanks Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
