Author Topic: Petrol tank repair  (Read 2275 times)
Offline Triumphant59
Petrol tank repair
« on: May 20, 2018, 09:13:46 AM »
Hi. New to site, restoring a 1977 400f. Not been on the road since 92 the tank has 3/4 very small rust holes on the underside. I've done a temporary repair using tank seal from Halfords but wondered what options there are for a more permananent repair? Could anyone also recommend someone to respray and fit decals to said tank, preferably in East Midlands area?
Re: Petrol tank repair
« Reply #1 on: May 20, 2018, 10:41:00 AM »
Hi, and welcome to the madhouse. Brazing or welding is a far more enduring repair, bur make sure whoever does it is familiar with motorcycle fuel tanks. A member on here's local garage offered to do it, but destroyed the tank and nearly blew themselves up as they didn't make sure it was completely clear of residual fumes, and left the filler cap on when they started welding! If your not too fussed about originality, Dave Silver Spares sell replica tanks for a reasonable price.
« Reply #2 on: May 20, 2018, 11:37:55 AM »
The bottom of the tank gets thin all over.  There's no point in repairing each pin hole as more will soon appear.  Furthermore,  the rust dust will block the fuel filter.  It's a better repair to cut the affected parts out, both sides, and weld in new sections.  As Hairy has said, find an expert to do the job.  As you may have guessed,  I've had this bother before.
Offline haynes66
« Reply #3 on: May 20, 2018, 04:07:46 PM »
look up MTS motorcycle tank repairs.  not cheap at  £50/hour but worth it.
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
« Reply #4 on: May 22, 2018, 08:11:29 PM »
Welcome to the forum. If it were me, I would buy a new tank.
Offline PatM
« Reply #5 on: May 24, 2018, 02:05:26 PM »
I have to agree with Nurse Julie- Id buy a new tank. I have a spare for the time when I have to revert to it, but some pattern parts are worth considering- exhaust, master cylinder have been fitted to mine as althouh I dont use the bike much- i want it to be reliable. theres nothing worse than a brakedown on a nice summer weekned due to leaking petrol- which will do more dan=mage than you think! The RAC/AA may not get you home if its a leaking fuel problem.
Tank repair is a specialist job and difficult to find a reliable supplier to do it. As mentioned earlier- theres the dangers, but given you can find someone to overcome that element- you are going to need a re-spray afterdards anyway as welding/brazing might seem localised, but the heat inviolved may well cause bubbling on the shiny-bits.
Offline UK Pete
« Reply #6 on: May 24, 2018, 06:47:47 PM »
I must agree new tank
However I have had an epoxy resin repair last over 5 years so you could take the chance
Offline Moorey
« Reply #7 on: May 25, 2018, 11:40:15 AM »
If it is just underneath they are easy to solder up, as long as you have a big iron to do it. I had to do mine nearly 3 years ago and it has been fine. I have also done others since and all have been good, and it doesn't damage the upper paint work;
I did this tank on this bike only 3 weeks after the whole bike was painted. He didn't expect to get away with not having to have it painted again.
« Reply #8 on: May 25, 2018, 01:20:30 PM »
See my comments above.  I'm glad it's worked for you but you'll be getting the iron out again before long.
Offline billywingnut
« Reply #9 on: May 25, 2018, 02:15:58 PM »
Hi, Once you've had it repaired be sure to use a tank liner and fit a new fuel filter. It's not cheap restoring one of these but good fun
« Reply #10 on: May 25, 2018, 02:18:39 PM »
Don't use a tank liner.
Offline Moorey
« Reply #11 on: May 25, 2018, 09:59:03 PM »
Time will tell on that one. As mine has been fine now for nearly 3 years and the tank is in regular use, how long are you giving it before I have to get the iron out again.  :)
« Reply #12 on: May 26, 2018, 01:14:03 AM »
My tank is in pretty good condition but I was thinking about using tank liner to make sure for the future. Why would that not be a good idea?
It would be great to save some time and cash if it's not necessary but I'm curious why that would not be good.
« Reply #13 on: May 26, 2018, 06:42:50 AM »
Because modern fuel (last 5 years) contains increasing amounts of ethanol, which turns lining materials to mush, allowing leaks to happen again, and blocking fuel taps and carb jets which a sticky mess.
« Reply #14 on: May 26, 2018, 08:13:28 AM »
There are now Ethanol proof liners, I'm sure that every lined tank Menno turns out is not a disaster. But I agree to a point, if you don't need it don't do it. With mine I used the same cleaner that comes with the liner kits to clean the insides of my tank. It came up spotless so I didn't line it. Bit of a problem if your tank leaks though, in this case a new tank would be my choice as they are available and the 400F paintwork is quite simple and cheap.
« Last Edit: May 26, 2018, 08:20:40 AM by royhall »
