Author Topic: Thread pitch?  (Read 1162 times)
Offline Arch stanton
Thread pitch?
« on: May 25, 2018, 10:29:46 PM »
Can anyone tell me the thread size & pitch in the hole where the brake pipe enters the Caliper on a Cb750f1?
As the threads on the Caliper I have is a bit festered & needs cleaning out.
Sean.
Re: Thread pitch?
« Reply #1 on: May 25, 2018, 10:41:23 PM »
I’m not sure what pitch it is but i know its the same size as a std banjo bolt if that helps...
Re: Thread pitch?
« Reply #2 on: May 26, 2018, 12:03:25 AM »
It's a start.
Cheers Rob.
Offline gtmdriver
Re: Thread pitch?
« Reply #3 on: June 04, 2018, 08:57:41 PM »
I think early Honda brake fittings are M10 x 1.25mm pitch.
Re: Thread pitch?
« Reply #4 on: June 04, 2018, 11:32:18 PM »
Cheers.
I was thinking they may have used something odd
Similar to yamaha on the RD's.
Sean.
Offline Underdog1
Re: Thread pitch?
« Reply #5 on: June 04, 2018, 11:42:06 PM »
It it simple to get braided brake hoses made up to go straight into the caliper without  using the standard metal pipe bit?
Re: Thread pitch?
« Reply #6 on: June 04, 2018, 11:50:15 PM »
Yep. I've got HEL braided hoses on mine. Any of the other manufacturers will supply the hoses.
Offline Underdog1
Re: Thread pitch?
« Reply #7 on: June 05, 2018, 11:02:31 AM »
Nice, i always thought these kits were a direct replacement for the standard hoses i.e. would need the rigid line still.
Re: Thread pitch?
« Reply #8 on: June 05, 2018, 11:40:18 AM »
Here's mine with HEL line going straight to the caliper, I preferred it that way.
Offline Simon46
Re: Thread pitch?
« Reply #9 on: June 05, 2018, 11:54:47 AM »
That hose looks tidy. And so is the shine on that metal!
1978 Cb750k8 US Import
Re: Thread pitch?
« Reply #10 on: June 05, 2018, 05:01:33 PM »
That is exactly what I'm trying to achieve. Only on double disc set up.
I'm really don't like the hoses going round the outside of the forks.
Thanks for posting.
Regards.
Sean.
Offline gtmdriver
Re: Thread pitch?
« Reply #11 on: June 06, 2018, 02:21:04 PM »
I've done exactly that too.
A single hose that goes from the brake light switch union to the caliper with an angled male fitting at the caliper end.
Offline Simon46
Re: Thread pitch?
« Reply #12 on: June 06, 2018, 06:14:20 PM »
I now need one. My 78 one piece hose ordered from cmsl showing 3 in stock is now no stock so money refunded. Where did you get yours?
Offline gtmdriver
Re: Thread pitch?
« Reply #13 on: June 06, 2018, 08:47:54 PM »
Offline Simon46
Re: Thread pitch?
« Reply #14 on: June 07, 2018, 03:29:35 PM »
Thanks gtmdriver. Have emailed him with a link to your bike pic. Internal diameter of banjo 10mm and 10x1.25 for the thread with vernier calipers. Regards Simon
