Author Topic: Thread pitch?  (Read 1221 times)
Offline Simon46
Re: Thread pitch?
« Reply #15 on: June 07, 2018, 06:11:29 PM »
Also the slave cylinder pipe end fit's into master when reversed if that helps anyone
1978 Cb750k8 US Import
Offline gtmdriver
Re: Thread pitch?
« Reply #16 on: June 07, 2018, 07:53:35 PM »
Furore cars will need the dimensions.
I have the schematics and if you PM me with your email I will send them over to you.
Offline Underdog1
Re: Thread pitch?
« Reply #17 on: June 07, 2018, 10:32:25 PM »
Are you able to post them up on here?
Offline gtmdriver
Re: Thread pitch?
« Reply #18 on: June 08, 2018, 02:46:05 PM »
Yes if you insist :-)
These are for a Honda CB350F. You will need to check the lengths against your own bike.
Upper Hose
Lower Hose
The second schematic shows the dimensions for a direct replacement but the best option is the alternative hose shown in the lower part of the diagram. It lines up nicely with all the original hose carriers.
« Last Edit: June 08, 2018, 02:47:53 PM by gtmdriver »
Offline Simon46
Re: Thread pitch?
« Reply #19 on: June 09, 2018, 12:03:47 PM »
With my 78 USA one piece hose I get 102 cm from centre of banjo to steel pipe end. Furore making it up in black at 103cm to be on the safe side.
Offline Underdog1
Re: Thread pitch?
« Reply #20 on: June 11, 2018, 05:52:45 PM »
So a one piece doesn’t use the brake switch? Or does the me 78 have it built into the lever assembly or something
Offline Simon46
Re: Thread pitch?
« Reply #21 on: June 11, 2018, 11:15:23 PM »
Mines a 78 USA import. One hose and brake switch in lever
