Author Topic: Clutch cable snapped  (Read 1226 times)
Re: Clutch cable snapped
« Reply #15 on: May 29, 2018, 09:31:43 PM »
Snap (literally)   ;D
Here is a pic of a broken push rod that has a very similar look to yours. These look like machined ends but are not, it is just a rotational wear pattern.
(Attachment Link)
That's a terrible pun
That's good for me John, I'm not a Master of Puns like yourself  ;D ;D
Offline jon stead
« Reply #16 on: May 29, 2018, 09:51:28 PM »
Snap (literally)   ;D
Yes, just like mine.
It was the way the two parts, that were joined together that I removed from the left hand side, rotated against each other that I was questioning. I get it now that I’ve removed the other, longer section, from the right hand side.
The attached pick should help describe what I’m trying to say. The two pieces with red arrows, are joined and freely rotate at the yellow arrow joint.
« Last Edit: May 29, 2018, 10:19:45 PM by jon stead »
Offline jon stead
« Reply #17 on: June 13, 2018, 10:20:08 PM »
Does anybody know the part number for the clutch push rod seal please? I can’t find it on the cmsnl exploded drawings.
Offline jon stead
« Reply #18 on: June 14, 2018, 02:40:39 PM »
91203-292-005 or 91203-292-003 depending on whose make it is. Both are correct, just different manufacturers.
Thanks Oddjob, much appreciated
