Author Topic: Grease Gun for 400 Swing Arm Nipple  (Read 478 times)
Offline Deano400
« on: May 29, 2018, 03:55:16 PM »
Hi All,
Trying to find a grease gun that will fit the 400 swing arm nipple. Can anyone let me where I can get one from? Thanks.
Offline gtmdriver
Re: Grease Gun for 400 Swing Arm Nipple
« Reply #1 on: May 29, 2018, 04:16:36 PM »
Conventional grease guns will not fit on the non-waisted grease nipples. I changed mine for the standard type but you have to search out the correct type as they are a knock-in fit rather than being threaded.
Offline sye
« Reply #2 on: May 29, 2018, 06:08:31 PM »
You need to change the coupler to a K type nipple adaptor. If you do a search there are plenty of options.
I think this should do the job: https://www.ebay.co.uk/itm/Lumatic-POC-1S-Push-Grease-Nipple-Connector-/132406115358?hash=item1ed404fc1e
« Last Edit: May 29, 2018, 08:40:47 PM by sye »
