Author Topic: F2 tank with K6 carbs, problem  (Read 1028 times)
Offline Green1
Re: F2 tank with K6 carbs, problem
« Reply #15 on: June 04, 2018, 07:12:08 PM »
I was going to suggest just turning the tap but thought you would just laugh at my simple but rather crappy solution.  ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline UK Pete
« Reply #16 on: June 05, 2018, 08:13:50 AM »
Tell us more about this project bike is it f2 with k engine k with f2 tank sounds interesting
« Reply #17 on: June 05, 2018, 08:28:34 AM »
I don't believe you did that Trig! A man of your skills and reputation resorting to a bodge like that, or is it a case of the customer not wanting to spend what's needed to do the job properly?
« Reply #18 on: June 05, 2018, 08:48:19 AM »
Trig IS the customer Hairy. Ita a bitsa he is buildings for himself out of bikes / bits laying around at home. You should know he would never, ever do a bodge on anything belonging to a customer.
« Reply #19 on: June 05, 2018, 09:03:11 AM »
Even so! Surely the best advert for his services would be everything done properly on his own bike?
« Reply #20 on: June 05, 2018, 09:08:41 AM »
It is not a bodge, it is an adaption. Very easy to access the tap. I will go back to it at a later date, when the sun is not shining ;)
I would never bodge with PTFE tape  >:(
« Last Edit: June 05, 2018, 09:10:41 AM by Trigger »
« Reply #21 on: June 05, 2018, 08:48:36 PM »
Shorten the choke lever, looks easy enough to do. By shorten I mean shorten the shaft length not the lever itself.
Would not work Ken. It is not just the choke lever, it is the linkage as well. Look at pic one and imagine the fuel tap hose.
Offline Green1
« Reply #22 on: June 05, 2018, 09:13:03 PM »
Just a thought can the hole rod assembly be mounted on the back of the carbs?
Current bikes
Honda CG125
Aprilia Pegaso 650
Kawasaki ZXR400 J
