Author Topic: 1970 (01/70) CB750 restoration  (Read 4185 times)
« on: June 09, 2018, 10:13:07 AM »
Thought I’d start this thread to document my latest K0 restoration...
The start...photo was taken back in 2016. Note the incorrect front end...correct K0 forks and single cut fender came with the bike and were temporarily re-fitted in late 2016.
« Last Edit: June 09, 2018, 11:53:04 AM by Jamesh_sussex »
Re: 1970 (01/70) CB750 restoration
« Reply #1 on: June 09, 2018, 11:00:03 AM »
Engine out of the frame and off to Graham for a rebuild (this was early last year).
Checking the condition of the frame prior to blasting / zinc priming.
« Reply #2 on: June 09, 2018, 11:04:46 AM »
Completed engine after lots of hard work (Graham’s hard work, not mine). The man is a legend.
« Reply #3 on: June 09, 2018, 11:08:20 AM »
Engine ready to go back in the frame, which has been stripped, zinc etch primed, flatted, 3 coats of satin, satin laquer finish (all black painted cycle parts have received the same treatment).
Probably a bit OTT if I’m honest as they were never this good from the factory.
« Last Edit: June 09, 2018, 12:23:10 PM by Jamesh_sussex »
« Reply #4 on: June 09, 2018, 11:13:12 AM »
Engine back in the frame, headstock rebuilt with new bearings..
« Last Edit: June 09, 2018, 11:14:43 AM by Jamesh_sussex »
« Reply #5 on: June 09, 2018, 11:18:53 AM »
Rebuilt forks back on. Refurbished swingarm refitted with Yamiya rear shocks.
New Honda rear fender (3 hole) fitted with refurbished original inner fender. As with the front fender I’ve opted for New Honda parts here rather than rechromed originals.
All electrics cleaned, checked, refitted. Genuine Stanley indicators.
I’m using a Yamiya CB Green body set for this one (bike was originally CB green).
Lots of original parts re-zinced. Some fasteners missing so have used a Yamiya No. ‘8’ bolt kit where necessary.
NOS Honda bars with new switch gear.
Ignore the ‘heath robinson’ jacking arrangement - it’s much more stable than it looks..(honest).
« Last Edit: June 09, 2018, 12:23:59 PM by Jamesh_sussex »
« Reply #6 on: June 09, 2018, 11:26:05 AM »
Plated parts ready to fit.
Both wheels fully stripped, rebuilt with new bearings, hubs polished/inners painted (my preference). Note front wheel bearings hadn’t been replaced in this photo (old seal and chewed up bearing retainer clearly visible).
« Last Edit: June 09, 2018, 12:25:42 PM by Jamesh_sussex »
« Reply #7 on: June 09, 2018, 11:29:09 AM »
Oil tank chemically stripped and repainted.
Front end fully rebuilt and brake system fully rebuilt with Honda parts.
Yamiya seat test-fitted.
Airbox upper test fitted.
Starting to look the part....
« Reply #8 on: June 09, 2018, 11:32:24 AM »
Back on her feet with new shoes on..(Conti RB2/K112).
All electrics wired and working.
Rear light fitted.
Original master cylinder stripped, painted, rebuilt with Honda m/c kit.
Using a Genuine Honda front fender (should have a single-cut front fender but small compromise here as even a re-chromed original wouldn’t quite hit the mark).
New oil lines from Germany rebuilt to OEM braided finish.
Original side panel emblems refurbished, ‘grilles’ repainted and assembled onto Yamiya covers. Fit of the side panel emblems is so much better with original compared to reproduction items.
Yamiya short rear chain guard fitted.
The CB-green colour is amazing IMHO.
« Last Edit: June 09, 2018, 12:27:07 PM by Jamesh_sussex »
« Reply #9 on: June 09, 2018, 11:38:43 AM »
Will be re-assembling the Carbs Tuesday evening so will post more pics then.
James
Offline Green1
« Reply #10 on: June 09, 2018, 12:14:10 PM »
Looking Great  8)
Shame we never get clean roads to use them on.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Honda CG125
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline UK Pete
« Reply #11 on: June 09, 2018, 12:45:57 PM »
Looks so good James
Wish I had the time and money to do the same to the many bikes I have laying around
« Reply #12 on: June 09, 2018, 01:21:07 PM »
   really brilliant,
   looking great .
   hope she rides as well as she looks
Offline Sgt.Pinback
« Reply #13 on: June 09, 2018, 02:27:48 PM »
Hi ...
How did you refurb the inner fender? I gave up and bought a new one.
Why wouldn’t a rechromed single cut fender be adequate ?
cheers, Uli
« Reply #14 on: June 09, 2018, 02:49:31 PM »
Hi ...
Wet/dry and then polishing compound Uli. My chrome supplier is pretty good, but doesn’t like doing fenders and it was easier/cheaper and a better finish to use a new Honda part.
