Author Topic: K2 Fuel Pipe Routing  (Read 1208 times)
« on: November 05, 2007, 08:57:41 PM »
I have a gold K2 in my garage at the moment that won't run as the fuel pipes are kinked where the PO has installed inline filters.
Can someone post a picture of the routing for the two fuel pipes?
At the moment they go down underneath the manifold, up between 3/4 and onto the fuel tap. Can't be right...
2022 Tiger Sport 660
Online mick
Re: K2 Fuel Pipe Routing
« Reply #1 on: November 05, 2007, 10:19:34 PM »
Hi Steve, on my 750 the fuel tap is on the right hand side with 2 outlets , front outlet petrol pipe goes above inlet rubbers then drops down & connects between 1&2 , and second outlet comes off tap down between 3&4 and connects to carb, they both feed the carbs from above , i had the same problem when i used inline filters so i took them off and up to now all is well , hope this helps mick. ;)
