Author Topic: DIY ultrasonic carb cleaning results  (Read 2721 times)
Offline MeilakJ
  • Life is what you make it!!
Re: DIY ultrasonic carb cleaning results
« Reply #15 on: June 18, 2018, 08:30:24 PM »
I Got a bath from ebay and allways works for me.
I use neutracon cleaner as it is suited for parts that can corrode .
http://www.decon.co.uk/english/neutracon.asp
I give them around an hour all parts and at 50 degrees and allways managed to clean them. Important is that if possible try to remove the bulky stuff prior to put it the ultrasonic bath .
Hope this works for you
John
Offline Andych
« Reply #16 on: June 20, 2018, 08:41:26 AM »
I soak all my carby stuff in Threebond before putting them into my Ultrasonic with a mix of an Orange (Citrus) type concentrated cleaner, a little dishwashing detergent, water and Vinegar.
This is an Aussie link but it is the same stuff Subaru use to spray into the intake to clean their intake tract and inlet valves.. you would be amazed at how it brings up manky carby parts green from ethanol fuels etc.
http://www.threebond.com.au/aerosols.html
1975 CB400 - Project
1978 Yamaha SRX250 - Project
