Author Topic: Gs550 running bad  (Read 1721 times)
Offline yozzer74
Re: Gs550 running bad
« Reply #15 on: August 26, 2018, 12:49:41 PM »
Philward it rides surprisingly good .bit bumpy at low speed but ok when speed picks up.k2 I was going to try bigger pilot jets ? Do you think floats position  will work
Offline Greg65
« Reply #16 on: August 26, 2018, 08:53:18 PM »
This link come from the GS Resources forum and is an invaluable guide to adjusting carbs. Hope it helps.
http://www.factorypro.com/tech_tuning_procedures/tuning_carbtune,CV,high_rpm_engines.html
All the best,
Greg
Edited to get the link working.
« Last Edit: August 26, 2018, 08:56:38 PM by Greg65 »
Keep smiling it makes the management nervous.
Honda CB400 1976
Suzuki GS1000 1978
« Reply #17 on: August 27, 2018, 08:20:38 AM »
It'll affect the lowest speed mixture more than the rest of the range but it's a real "suck it and see" to judge how much it can influence it.
Ultimately it appears to need just a little more fuel metered to clean up that low speed response (verified by the improvements you get with the screw setting)  so whichever is convenient to change first is worth trying.
