Author Topic: 650sc/750chop  (Read 2539 times)
sweepy
650sc/750chop
« on: November 16, 2007, 11:43:26 AM »
Hi this is what I am trying to do I have a 650sc 1982 engine SOHC with no carbs or ignition, I am going to use carbs of a CB650z and points ignition of a 1983 engine. The uinit is to go into a 1982 chopped cb750 frame using front forks  and wheel off a f1. The rear wheel is disc braked wire spoked and is off an early cb650, I am not sure what, but I have a brake caliper and disc that fit the disc seems to be larger than the f1 front disc. I have some alternative choices in a   500vt front end complete, a 500cx front end complete a comstar rear wheel (disc) I think its of a 750.
Bits I am struggling to find are exhaust headers any condition as I only want the first 6-8 inches and I will fabricate the rest.
This chop iis being built from parts obtained on Ebay and not from a complete bike.
Every thing looks straight forward except setting the engine up I woild be grateful for any comments.
thanks sweep
Re: 650sc/750chop
« Reply #1 on: November 16, 2007, 12:02:42 PM »
If you're not fussed about the silencers, your best bet for 650 headers is a breakers.  They probably just toss the rusty ones in a skip.
2022 Tiger Sport 660
Offline pae
    • Phil's CB650 pages
Re: 650sc/750chop
« Reply #2 on: November 17, 2007, 08:59:30 AM »
Hi Sweepy, try over here >>> http://www.hondacb650.com/
regards, Phil
