Author Topic: Speedo bulb lead/holder  (Read 674 times)
« on: June 22, 2018, 10:29:43 AM »
  does anyone know the part number,and/or a source to get a new cable with a decent rubber socket were it fits into the Speedo  ??
  this link is CMSNL.com ,it shows the items,but no number
  https://images.cmsnl.com/img/partslists/honda-cb500k1-four-england-speedometer-tachometer_bigma000083f20_c8e9.gif
Offline kent400
Re: Speedo bulb lead/holder
« Reply #1 on: June 22, 2018, 12:55:43 PM »
I should have one John that's decent. Any idea how long the cable is? Armed with that I have a look it will be FOC of course.
« Reply #2 on: June 22, 2018, 03:09:02 PM »
They never came separate from a clock Honda probably thought we would fall off and need a new clock before the wiring needed replacement, early clocks had one bulb later had two
« Reply #3 on: June 22, 2018, 07:10:05 PM »
  thanks,just checked ,it connects with the loom in the headlamp,I guesstamate it about 1ft long,the  spedo is a 500 K1 single bulb,
 I intend to get in touch in a few months,I have a CB200 that needs its dials refurbed
 thanks
Offline kent400
« Reply #4 on: June 22, 2018, 07:51:45 PM »
Yep got one, it's 14 inches long but you will be able to loose a couple of inches if necessary.  Single bulb holder of course and it looks like it has never been used. I'll get it off to you.
« Reply #5 on: June 22, 2018, 09:15:52 PM »
  many thanks
