Author Topic: Bleeding brakes  (Read 477 times)
Offline Triumphant59
Bleeding brakes
« on: June 24, 2018, 04:28:54 PM »
Just renewed brake system on my 400f; new slave piston and seal, 3 new brake pipes and replaced master cylinder piston cw new seals fitted correctly, the old master cylinder wasn't pitted. I have filled res, opened bleed screw and pumped lever expecting level in res to go down and nothing happens, just a few bubbles coming from the holes in bottom of res! Any ideas
Offline petermigreen
Re: Bleeding brakes
« Reply #1 on: June 24, 2018, 04:59:57 PM »
Make sure the smaller return hole in the bottom of the reservoir is clear. It's tiny and you may need to pass a very thin wire or pin head or even better carb cleaning tool through it. If it's blocked the system won't work.
Good luck.
Peter
Re: Bleeding brakes
« Reply #2 on: June 24, 2018, 06:10:57 PM »
Sorted, thank you Peter. I have to say this forum is brilliant!!!
Re: Bleeding brakes
« Reply #3 on: June 24, 2018, 09:10:59 PM »
Result
