Author Topic: CB400 F Centre Stand Removal  (Read 2011 times)
Offline ogri211
Re: CB400 F Centre Stand Removal
« Reply #15 on: July 04, 2018, 07:15:42 AM »
I as well had that problem with mine and I have had it with previous bikes with the tube type pins. The problem is when they corrode if you try and drift them out they start to miss form and collapse, I used the saw method but I had a cengar saw with a hacksaw blade on some you have to grind a bit off the blade but not the Honda . The solid type pin is a sensible upgrade as it can be drifted out easy but that shouldn't happen with the type of easy life these bikes are getting now compared to the all year use when they were new.  Make sure to clean the inside of the stand tube with emery or scotchbrite and the pin is a smooth fit and remember to grease it.
« Last Edit: July 04, 2018, 09:59:40 PM by ogri211 »
Triumph Rocket3, Suzuki GT 750A, Kawasaki H1B, Honda 400 Four, Triumph Speed Triple
Offline waffey
« Reply #16 on: July 04, 2018, 07:22:08 AM »
I cant afford to get the bike to 'as mr Honda made' condition but I do intend to get it to look like it is from a showroom. I'll go with the solid bar and be done with it  ;D
Bikes:
Triumph Street Twin
Suzuki Address 110 Scooter
Suzuki TL1000s
BMW R1200GS LC
Offline waffey
« Reply #17 on: July 04, 2018, 11:31:20 AM »
its hollow, that's why I didn't beat the hell out of it!!!!!
Bikes:
Triumph Street Twin
Suzuki TL1000s
BMW R1200GS LC
Offline Sprocket
« Reply #18 on: August 28, 2018, 10:31:15 AM »
So, as per my project thread, I've got as far as cutting a slot along the length with a (modified) hacksaw blade, but it's still not moving anywhere. I think I might try and cut another slot a bit further round, to remove a chunk of the tube and get it moving.
« Reply #19 on: August 28, 2018, 10:45:56 AM »
That's the best way to do it, do the second cut fairly close to the first ( 5-10mm away) then with an old screwdriver or similar try tapping the thin strip in towards the middle. Once that is done it gives you space to crush the main part of the tube towards the centre, then it will come out.
Offline Spenny62
« Reply #20 on: August 28, 2018, 04:11:17 PM »
One of the Centre stand lugs on mine has broken off. Presumably when the previous owner (honest) was trying to remove it. Does anyone make and supply a pattern part replacement or will I have to get one fabricated and welded in?
Offline Clem2112
  • Midlife
« Reply #21 on: August 28, 2018, 06:00:09 PM »
Get a heat gun on it which should help separate the two.
That plus the persuader got mine apart, although I don't recall that much bother.
Plenty of ACF50 (grease) on the two surfaces before re-assembly as well.
