Author Topic: Breather pipe  (Read 498 times)
Offline boilermaker1
Breather pipe
« on: July 05, 2018, 10:33:43 PM »
Can any tell me the correct routing of the breather pipe
That goes from the rocker cover to the bottom of the air
filter on a 400 4
Re: Breather pipe
« Reply #1 on: July 05, 2018, 10:45:32 PM »
Down between the front of the carbs,  between carbs 2 and 3 and up to bottom of airbox.
Like so:
« Last Edit: July 05, 2018, 10:55:18 PM by Nurse Julie »
Re: Breather pipe
« Reply #2 on: July 05, 2018, 10:58:23 PM »
Thanks for reply Julie , what type of pipe connects to bottom of airbox?
Re: Breather pipe
« Reply #3 on: July 05, 2018, 11:15:06 PM »
Its just a rubber drain tube that goes to atmosphere. 1 piece. I think originally they had a little squeeze piece that you were meant to squeeze at service to let any moisture out. I haven't got that type on mine any more, just a length of rubber tubing which does the job just fine.
