Author Topic: Erratic speedo  (Read 401 times)
Offline paulbaker1954
Erratic speedo
« on: July 13, 2018, 12:27:53 AM »
Has become somewhat sticky and jumpy above 60
Know cable and drives and cushions are all ok
Is there a way of lubricating the internals without stripping it?
2016 Yamaha MT09 Tracer
1971 Honda CB500 Four K0
Offline kent400
Re: Erratic speedo
« Reply #1 on: July 13, 2018, 07:00:08 AM »
Short answer no, it will probably end up on the inside of the glass and the only lubricant they contain is a small amount of grease on mileage counter gears.
You could test the gauge with a power drill that has a reverse facility connecting an old cable between the two running it up to speed. This isn't a definitive test as the gauge isn't then subjected to the vibration it is when fitted.
