Author Topic: 400/4 Jumping out of gear  (Read 828 times)
Davelu88
« on: July 26, 2018, 03:41:09 PM »
400/4 jumping out of 1st gear back into neutral, don't do it in other gears, I have adjusted clutch  by the manual to the best of my ability which isn't much!! but no joy, any help greatly appreciated.
« Last Edit: July 26, 2018, 04:26:39 PM by Davelu88 »
Offline ka-ja
  • ken
  • yoshi 460
Re: 400/4 Jumping out of gear
« Reply #1 on: July 26, 2018, 07:59:33 PM »
Worst scenario is the dogs or slots on the gears have worn to slight tapers, but 1st gear might not be fully engaged, I would take a look at the selector mechanism if the fault persists
nice bike,nothing in the bank
Davelu88
« Reply #2 on: July 26, 2018, 08:24:58 PM »
Many Thanks
Online Bryanj
« Reply #3 on: July 27, 2018, 07:17:35 AM »
40 was the best box and rarely gave trouble, is the gearlever movement blocked or lever bent>
Davelu88
« Reply #4 on: July 27, 2018, 08:38:21 AM »
Not to my knowledge , it was ok then the other day was jumping out of 1st when pulling away , I had to adjust the clutch as had a bit of slippage and that seems a bit better but gear still jumps
Online Bryanj
« Reply #5 on: July 27, 2018, 12:39:59 PM »
Very unusual, you need to check the change/detent mechanism behind the clutch. Do it soon as if it is the detent it will wear all the gear dogs
Davelu88
« Reply #6 on: July 27, 2018, 04:29:37 PM »
Engines coming out for a rebuild soon , so will stop riding it until sorted , thanks for info
« Reply #7 on: July 27, 2018, 04:37:43 PM »
Davelu88
« Reply #8 on: July 27, 2018, 05:35:09 PM »
In fact I took it out today in anticipation lol
Offline Athame57
    • SeaWitch Artist
« Reply #9 on: August 01, 2018, 02:55:08 PM »
I had this sort of problem for a few weeks recently, 1st gear would only engage and stay so if the engine was still cold after which it was lost. I messed with the clutch no end and worried about needing to split the crank. I had this trouble as soon as I bought her so I had the hump with the seller, an online classic bikes seller.
Then a hunch and I discovered all I ever had to do was adjust the gear change lever a few millimeters! Works fine now.
1978 CB400F2 called Elen.
Davelu88
« Reply #10 on: August 01, 2018, 03:38:36 PM »
Thanks for that , i have now taken the engine out as its getting a rebuild soon , but as i was coming to undo the gear linkage i noticed it was loose but then i had the (had i or hadnt i just undone that thought ) so im hoping it was just a loose gear linkage. ;D
